PutFiles does not overwrite the existing file.
kmihin
I have a file uploaded test.txt. Inside there is just "test". When I upload a new file with PutFiles function the file has the same name but different content, it says that the upload succeeded but when i check the file it hasn't changed.
Re: PutFiles does not overwrite the existing file.
Tbh, it is quite unlikely. How do you test that the file has not changed?
If you want us to investigate anyway, please attach a full session log file showing the problem (using the latest version of WinSCP).
