SSL Certificate from the command line
briandent
I'm on 5.21.6.
I had to update my SSL certificate but now I can't get my batch file to save it.
The command line is shown below and when I run it interactively from the command prompt I get message
the certificate is unknown. I've answered y but it doesn't save the cert. In the past I was able to
use the app and save the certificate there. Then I wasn't prompted again. I've tried the
-certificate and -host flags but those haven't worked. What am I missing?
  /log="%~dp0%~n0_winscp.log" /ini=nul ^
  /command ^
    "open ftpes://offsite:xxxxxxxx@ash.compudent.us/ -rawsettings ProxyPort=1 MinTlsVersion=11" ^
    "lcd %BACKUPDATA5TB%\BERYL\DATA" ^
    "cd /OFFSITE" ^
    "put -filemask=""*.txt>2D;*.log>2D;*.7z>2D;*.zip>2D;*.zipx>2D"" -neweronly -rawtransfersettings[2] PreserveTimeDirs=1 ExcludeEmptyDirectories=1 *" ^
    "exit" >> %~dp0%~n0.log
The server's certificate is not known. You have no guarantee that the server is the computer you think it is.
Server's certificate details follow:
Issuer:
- Organization: DigiCert Inc, www.digicert.com, RapidSSL TLS RSA CA G1
Subject:
- Organization: *.compudent.us
Valid: 1/9/2024 12:00:00 AM - 1/12/2025 11:59:59 PM
Fingerprints:
- SHA-256: 22:cf:ab:6c:9d:37:9d:07:3e:4d:c9:7a:70:e4:24:04:67:86:cd:3f:23:9c:1a:de:df:22:6c:38:da:ff:34:ba
- SHA-1: 1d:86:3e:ed:ec:79:df:08:f4:06:47:7c:86:1f:cb:fd:5f:65:cf:53
Summary: Self-signed certificate in certificate chain. The error occurred at a depth of 3 in the certificate chain.
If you trust this certificate, press Yes. To connect without storing certificate, press No. To abandon the connection press Cancel.
Continue connecting and store the certificate?
(Y)es, (N)o, C(a)ncel (8 s), (C)opy Key:
Re: SSL Certificate from the command line
Using the -certificate switch is the correct approach.
But you didn't tell us how exactly did you use it.
It should be like:
    "open ftpes://offsite:xxxxxxxx@ash.compudent.us/ -certificate=""22:cf:ab:6c:9d:37:9d:07:3e:4d:c9:7a:70:e4:24:04:67:86:cd:3f:23:9c:1a:de:df:22:6c:38:da:ff:34:ba"" -rawsettings ProxyPort=1 MinTlsVersion=11" ^
briandent
SSL Certificate from the command line - permanent
Thank you for your help. I was missing the double "'s.
Is there a way to save this certificate so the -certificate flag is not necessary?
Thank you again.
