Moving files caused other file disappear
Arnoxas
So I have folder imports and in folder imports there is 2 folders named car and car2 and I moved 3 files from folder carpack to imports/car and all files in imports/car disappeared and only left moved files, where do files disappeared?
Re: Moving files caused other file disappear
Are you sure you moved files? Haven't you moved whole folder? Can you reproduce the problem? If you can, please attach a full session log file showing the problem (using the latest version of WinSCP).
