Cannot create remote file '/home/.../class_..._posts_cleanup_sc_util.php'
kitchin
Virginia
(File names munged in this report - if you need them, tell me.)
Level: Not serious, but not ideal.
Steps to reproduce: Let a session go stale, for instance, by stepping away from the computer for an hour. The screen shows "Reconnect Session" on the right-hand panel. Double-click on a file in the left-hand panel to upload it.
Result: Error.
Expected result: Reconnect and upload file, or just a warning instead of an error.
WinSCP 6.2.2
Cannot create remote file '/home/.../class_..._posts_cleanup_sc_util.php'.
(00BC5B8A)
(00E1EB06)
(00E20B6E)
(00E1D928)
(0009812F) ntdll.dll
(00BC410B)
(00C1DA40)
(00C20879)
(00C46BCF)
(00C46DE0)
(00C5F19D)
(00C42C57)
(00C7A283)
(00C78900)
(00C7872D)
(00C4109A)
(00C7818C)
(00011F33)
(00012B54)
(00012DD0)
(0001E447)
(0005C272)
(0048D049)
(0048A9B6)
(0048B5F5)
(00407B29)
(0044AE03)
(00225850)
(00031E51) USER32.dll
(00022C21) USER32.dll
(00022592) USER32.dll.CallWindowProcW
(0007F334) COMCTL32.DLL
(0007F3D3) COMCTL32.DLL
(0007F14C) COMCTL32.DLL
(004C1947)
(00225850)
(000214E0) USER32.dll
(0002102B) USER32.dll.DispatchMessageW
(00E1F171)
(00E2074B)
(00C477F7)
(00C5F19D)
(00C42C57)
(00C7A283)
(00C78900)
(00C7872D)
(00C4109A)
(00C7818C)
(00011F33)
(00012B54)
(00012DD0)
(0001E447)
(0005C272)
(0048D049)
(0048A9B6)
(0048B5F5)
(00407B29)
(0044AE03)
(00225850)
(004C1947)
(00225850)
Status: unknown_rel_addr
Re: Cannot create remote file '/home/.../class_..._posts_cleanup_sc_util.php'
@kitchin: Thanks for your report.
