Unnecessary windows notification with two instances to same server with one active
Waruwaru
Deutschland
Hello, I have 2 instances open to the same server. One instance is in background for synchronize and one is open and working with.
If I now copy a file in the active WinSCP and it is finished, a Windows notification now appears that the queue is empty. Normally you only get this when the application is in the background. But here I am directly in it and it is active. I assume that because a second connection (in background) to the same server exists?
Since I have the window open and am actively working with it, I do not need a Windows notification for this instance. For the other instance in the background, there should of course be a notification.
I hope that has been understood somehow :)
Re: Unnecessary windows notification with two instances to same server with one active
Isn't it the other background instance that pops the notification?
Aren't you downloading in the active instance (and that triggers re-upload of the newly downloaded file in the background instance)?
