bigfatgreedykat
Hello all
I am using scripting option. Is it possible to GET a file for today's date.
Look forward to any replies!
BFGK
I'm not sure if I understand. Do you want to download only files created "today"?
bigfatgreedykat
Hello
Yes, i would like to download todays file using script=*.txt option.
Is this possible?
regards
BFGK
No.
But if the older files are already in the local directory, you can use synchronize function to download only new files.
bigfatgreedykat
Hello
is there an example of "synchronize function"
regards
BFGK
Type "help synchronize" into console.
bigfatgreedykat
Hello
This appears simple enough, thanks
But can it be written into script?
regards
BFGK
bigfatgreedykat
Hello
Worked out how to download files from remote to local:
synchronize local
However, only need today's file.
Any ideas?
regards
Jai
Again, if you keep all the file in the local directory, only the new (totady's) files will be downloaded.
bigfatgreedykat
Hello
Sychronize works perfectly now from script.
However, just need to download from remote to local a specific file extension.
Please advise.
BGFK
