Script didn't save the downloaded files correct
piti87
I have the following script (PowerShell)
param (
    $localPathImport = "C:\application\Data\12345\Import\SAP\PROJEKTE\",
    $remotePath = "/test/download/*"
try
    # WinSCP .NET assembly laden
    Add-Type -Path "WinSCPnet.dll"
    # Session Einstellungen
        HostName = "host.net"
        UserName = "user_ftp"
        SshHostKeyFingerprint = "xxx"
        SshPrivateKeyPath = "C:\application\AddOns\File_upload\ssh\private_key_cust01_new.ppk"
    try
        # Verbinden
        # Download
        $transferResult = $session.GetFiles($remotePath, $localPath)
            # Download erfolgt oder Error?
            if ($transfer.Error -eq $Null)
                $zeit = Get-Date >> C:\application\AddOns\File_upload\download_sap_projektstamm_log.txt
                Write-output "Download von $($transfer.FileName) erfolgt!" >> C:\application\AddOns\File_upload\download_sap_projektstamm_log.txt
            else
                $zeit = Get-Date >> C:\application\AddOns\File_upload\download_sap_projektstamm_error.txt
                Write-output "Download von $($transfer.FileName) fehlgeschlagen: $($transfer.Error.Message)" >> C:\application\AddOns\File_upload\download_sap_projektstamm_error.txt
        # löschen aus Verzeichnis
        $session.RemoveFiles($remotePath)
    finally
        # Verbindung trennen
        $session.Dispose()
    exit 0
catch
    Write-output "Error: $($_.Exception.Message)" >> C:\application\AddOns\File_upload\download_sap_projektstamm_error.txt
    exit 1
The script does not save the files in the $localPathImport.
The three files on the FTP server are:
project0000000000001319
project0000000000001320
project0000000000001321
It makes a file named %22 in the directory, where is the winscp.exe located. And in this file %22, the content of the three files are combined.
Any ideas?
Re: Script didn't save the downloaded files correct
You never use $localPathImport in your code. Maybe you wanted to use it, where you actually use undefined $localPath.
Also, what do you expect the $zeit = Get-Date >> ... to do? Imo, the $zeit = Get-Date does not output anything. Possibly you meant to do Get-Date >> ... only.
If you need further help, please attach a full session log file showing the problem (using the latest version of WinSCP).
