Unable to download file >1MB; upload works ever
LMO_Davide
Hello, everyone,
I cannot download files larger than one mega because the session goes into timeout, the server does not respond and my session is closed. When I try to upload a file of any size I have no problem.
Protocol: SCP
Target: unix server
I have already set 'Optimise buffer size', it does not work even if it is disabled.
I did the same test with SFTP, I have the same behaviour.
I attach logs.
Description: Session log
Re: Unable to download file >1MB; upload works ever
Please post log with "Optimise buffer size" off.
Can you download the file using any other client?
Re: RE: Unable to download file >1MB; upload works ever
Complete log please.
Why you cannot try other client?
LMO_Davide
The logs are completed, sir.
The connection is mediated by a cyberark component that functions as a proxy, so it does not support other client types.
d
I'm having the same issue
I can upload a file without issue, but when trying to download it fails with error 4.
This does work with other FTP tools like FileZilla
