WinSCP sometimes it doesn't show files
TAIFUN
TAIFUN avatar
Hi!
P.S. I restarted the program and computer. It does not help.
Re: WinSCP sometimes it doesn't show files
When it happens, is it always the right panel? Can you see the missing files in the same directory in the local panel?
Is the problem that the panel is completely empty? Does it always lacks even the ..? Or are just some files sometime missing and some visible?
Is the D: local or network drive?
TAIFUN
TAIFUN avatar
Sometimes. Maybe this is due to the fact that the program cannot display files if the path to them is long? I don`t know.
If there is a problem with the folder, it is always empty.
Disk "D"
TAIFUN
TAIFUN avatar
This is caused due to long path.
I archived the folder that I tried to open in the program. Unpack it and try to open the files along the path:
se*-url-generator-pro__unzip-me__v3.5.4 >>>
install-files >>>
2.3 >>>
* unpacked SE*-URL-GeneratorPRO_for-OpenCart_2.3.ocmod * >>>
open folder >>>
upload >>>
admin >>>
view >>>
template >>>
extension >>>
module >>>
You can see files se*_url_generator.tpl and se*_url_generator_generate.tpl ?
Yes I can see the files.
Though your ZIP files contain long names, contrary to your screenshot with a short name (SE*-UR~1).
Can you either (or both): send me a ZIP of complete exact directory structure necessary to reproduce the problem – or the trace log from the debug version I've sent you?
TAIFUN
TAIFUN avatar
Because you unpacked the archive in the root of the disk. For this reason, the path to the files is much shorter than in my case.
Could you put the archive in the path:
Disk D > Install > Форум > Интернет Магазины > OpenCart > Плагины и модули > SEK URL Generator PRO для OpenCart 2x & 3.x - Translit
... and then unpack it and check.. can you see files?
