Log file growing larger than specified limit
rblair@caliberpublicsafety.com
Arkansas
Below are the parameters of my batch script. Based on my understanding, my log file size should be limited to 10MB and I would only have 5 log files in retention. However, as it sits, my log file 101MB and still growing. Please let me know what I might be missing.
  /log="E:\ftplog\WinSCP.log" /ini=nul /logsize=5*10M ^
  /command ^
   "open  redacted" ^
    "option batch continue" ^
   "option confirm off" ^
   "lcd E:\Peraton" ^
    "cd /" ^
    "put -delete *.xml" ^
    "exit"
Re: Log file growing larger than specified limit
Your syntax looks good. Make sure you have up to date version of WinSCP. If you have, please attach the session log (or just its header).
