Can't select multiple files
Hello, I can't download more than one file at a time. When I try to select more than one file I'm not able to select with control or shift. Your instructions say use space bar or insert key and that doesn't work either. Any ideas? Thank you.
Version 5.19.2
Asus Laptop Windows 10
Version 5.19.2
