Messages of error and transfer percentage from WINSCP
above all I must congratulate for the product and the forum maintained in a very proper manner.
I am in need of using WINSCP in a hidden way, implemented with VB6.
I am disappointed that there is no library to be reutilized with other applications.
So I am planning to use a temporary batch file to be used by WINSCP3.COM.
I prepare a batch file with all the necessary commands and read it with DOS PROMPT COMMANDS.
My problem is to know how can I recover the message of each put or get, percentage of transfer, whether it is gone good without error.
Hope to have been clear.
Thanks for the prompt reply.
Re: Messages of error and transfer percentage from WINSCP
You should be able to read output of the console. See WinAPI function ReadConsoleOutput.
