How to get files from hidden folder using PowerShell script.
sasticgopi
India
$Source = "/home/.Archive/"
$Directory = $session.ListDirectory($Source)
Above code getting error if folder contains "dot" in prefix.
Re: How to get files from hidden folder using PowerShell script.
Is the folder even available via the protocol you are using?
Can you access it in WinSCP GUI or any other client (using the same protocol)?
