worcester
Customer - Joined:
- 3
Cannot find config file
Site Admin -
- 43,049
- Prague, Czechia
Re: Cannot find config file
Windows Store sandboxes some folders.
See for example Special Name for Microsoft Store App User Data Locations (like %appdata%)?.
So you will find that file in
Though I wonder why do you want to use an INI file with Windows Store installation. INI file is mostly useful for portable use only.
%LOCALAPPDATA%\Packages\MartinPikryl.WinSCP_tvv458r3h9r5m\LocalCache\Roaming\winscp.ini.
worcester
Customer - Joined:
- 3
Thanks for the instruction. I have successfully found the config file.
I was doing an SSD upgrade on my laptop, so I needed to migrate my config files. At first, I followed the documentation which says WinSCP defaults to using the Windows registry, but with no luck. After reinstalling WinSCP on the new drive, I found on the settings page that the default location is the INI file.
The Windows Store installation on my computer defaults to using INI files.Though I wonder why do you want to use an INI file with Windows Store installation. INI file is mostly useful for portable use only.
Site Admin -
Indeed, there seems to be some change or bug in Windows 11 that causes WinSCP to default to using an INI file. Thanks.
Issue 2245 – Windows Store installation on Windows 11 was incorrectly using INI file for configuration storage by default
worcester
Customer
I switched to registry in the settings, however I still couldn't find the configuration in the desired path. Does Windows registry have a similar sandboxing mechanism for UWP as well?
Site Admin -
Yes, it has.
