Can't open 2 tabs and connect to same server when logging is enabled
If I open a second tab to connect to same server, and logging is enabled, a popup appears saying:
Accept closes the popup but it comes back right after, and I am stuck with the popup.
Help doesn't offer anything helpful, it says to submit message online but there are 0 search results.
So I am stuck with a popup that blocks the entire program from doing anything else.
The error makes sense, the problem is it should go away and not come back.
Translated to English:Error del sistema. Código: 32.
El proceso no tiene acceso al archivo porque está siendo utilizado por otro proceso
This popup has 2 buttons: Accept & HelpSystem error. Code: 32.
The process does not have access to the archive, but it can be used by other processes
