Cannot find .com File
polat
Hi all,
to use WinSCP via COM interop have to register it via regasm
But it will not create a .com file.
Did I misunderstood something?
In past I called in DOS winscp.com with following parameters /console /script:
call "C:\xx\xx\WinSCP\WinSCP.com" /console /script="\\xx\WinSCP\downloadOBE.winscp"
Re: Cannot find .com File
Well, yes you seem to have misunderstood something. But without mode context it's hard to say what it is.
If you want to use WinSCP .NET assembly, you do not need winscp.com.
Conversely, if you want to use winscp.com scripting, you do not need WinSCP .NET assembly, let only any registration.
