Need find option to change the buffer settings
leo7123
Get.location
Hello, I need find option "Optimize connection buffer size".
On the help page there is very very old image and there is no connected with the last version of WinSCP.
I need EXACTLY step by step where is this option.
Thanks!
Re: Need find option to change the buffer settings
So you gave us 1 star review, falsely claiming that our documentation screenshots are obsolete:
https://sourceforge.net/projects/winscp/reviews/
And yet you ask for help.
The answer is still the same: the screenshot in the documentation is up to date:
https://winscp.net/eng/docs/ui_login_connection
And nothing has changed about that screen for over 10 years!
You find the screen by clicking Advanced button on the Login dialog and going to the Connection page.
Re: Option
What do you mean? I've responded you at the same time, I've responded everyone else.
The option is exactly, where I wrote it is in my previous post above:
What you have posted is a screenshot of the "Preferences" dialog.
Re: where
Go to the Login dialog (Ctrl+N), select your stored site, click Edit, and then Advanced. Go to the Connection page.
Re: ok
I do not know what you want to do.
You have only wrote us that you are looking for "Optimize connection buffer size" option. You have found it now.
If you want to turn it off, then turn it off.
