User with Character @ in SFTP account username and automation
jpantera
Los Angeles, CA
Hello Martin, WinSCP Support,
Have a new file transfer to setup, and I use the automation script file method, building the
open sftp://<username>@<remote address>:<Port> -privatekey=<File> (Options)
connection string on the fly, automated.
This new file transfer, has the character @ in the username, so this statement will say something like
open sftp://joe@pantera@<remote address>:<Port> -privatekey=<File> (Options)
Do I need to add logic to escape the first @ character? Is that needed, or what is the recommendation?
Thanks,
Joe P.
jpantera
Los Angeles, CA
Thank you Martin!
Does the -username work with the open sftp://<Site> command in some way?
I'm getting error:
Unknown switch 'username'.
(But substituting %%40" for @ seems to work).
- Joe P.
You are possibly using old version of WinSCP that does not support -username.
If you have the latest version and it still does not work, please post your code.
