Exception: No handle of the given name exists.
Autocp
This code runs successfully every day, except Saturdays:
param(
#### CONFIGURE FILEPATHS ####
    $xmlConfig = "C:\Batch\SFTP_Automation\Config.xml",
    $unrar_path = "C:\Users\USERNAME\AppData\Local\Programs\WinRAR\unrar",
    $RemoteFilePath = "/Daily",
    $LocalFilePath = "C:\mis",
    $LogFilePath = "C:\Batch\SFTP_Automation\Daily\Reports\Logs",
    $DailyExtracts = "C:\MIS\DailyExtracts",
#### DYNAMIC NAMING CONVENTIONS ####
    ${ddMMMyyyy} = (Get-Date).ToString("ddMMMyyyy"),
    ${yyyyMMdd} = (Get-Date).ToString("yyyyMMdd"),
    $FILENAME_Folder = (Get-Date).ToString("\MIS_DAILY_ddMMMyyyy"),
    $FILENAME_File = (Get-Date).adddays(-1).ToString("\MIS_dd")
#Record PowerShell Transcript
Start-Transcript -Path "$LogFilePath\${yyyyMMdd}_SFTP_MIS_Daily_Transcript.log"
[xml]$Config = Get-Content $xmlConfig
# Load WinSCP .NET assembly
# Set up session options
    HostName = $Config.Configuration.HostIP
    UserName = $Config.Configuration.UserName
    Password = $Config.Configuration.password
    PrivateKeyPassphrase = $Config.Configuration.PassPhrase
    SshHostKeyFingerprint = $Config.Configuration.FingerPrint
    SshPrivateKeyPath = $Config.Configuration.SshPrivateKeyPath
    Timeout = New-TimeSpan -Minutes 10
    $session.SessionLogPath = "$LogFilePath\${yyyyMMdd}_SFTP_MIS_Daily_Session.log"
    $session.DebugLogLevel = 2
    $session.DebugLogPath = "$LogFilePath\${yyyyMMdd}_SFTP_MIS_Daily_Debug.log"
try
    # Connect
    $session.GetFiles("$RemoteFilePath/MIS_*.exe","$LocalFilePath\MIS_DAILY_${ddMMMyyyy}\",$false,$transferOptions)
finally
    $session.Dispose()
Notice that I have set the timeout to 10 minutes in the $SessionOptions section. This was an attempt to address a timeout error that I am still getting from this transcript:
Windows PowerShell transcript start
Start time: 20231014051649
Username: DOMAIN_NAME\USERNAME
RunAs User: DOMAIN_NAME\USERNAME
Machine: A0208C03 (Microsoft Windows NT 10.0.14393.0)
Host Application: C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe C:\Batch\SFTP_Automation\Daily\Reports\Daily_MIS.ps1
Process ID: 10136
PSVersion: 5.1.14393.5582
PSEdition: Desktop
PSCompatibleVersions: 1.0, 2.0, 3.0, 4.0, 5.0, 5.1.14393.5582
BuildVersion: 10.0.14393.5582
CLRVersion: 4.0.30319.42000
WSManStackVersion: 3.0
PSRemotingProtocolVersion: 2.3
SerializationVersion: 1.1.0.1
Transcript started, output file is C:\Batch\SFTP_Automation\Daily\Reports\Logs\20231014_SFTP_MIS_Daily_Transcript.log
Mode                LastWriteTime         Length Name
d-----        14Oct2023   5:18 AM                MIS_DAILY_14Oct2023
Exception calling "Open" with "1" argument(s): "Timeout waiting for WinSCP to respond - WinSCP has not responded in
time. There was no output. Response log file C:\Users\USERNAME\AppData\Local\Temp\wscp2798.03302225.tmp was not created.
This could indicate lack of write permissions to the log folder or problems starting WinSCP itself."
At C:\Batch\SFTP_Automation\Daily\Reports\Daily_MIS.ps1:45 char:5
+     $session.Open($sessionOptions)
    + CategoryInfo          : NotSpecified: (:) [], MethodInvocationException
    + FullyQualifiedErrorId : TimeoutException
has not responded in time. There was no output. Response log file
C:\Users\USERNAME\AppData\Local\Temp\wscp2798.03302225.tmp was not created. This could indicate
PS>$global:?
True
I have attached a debug log. It looks like it is timing out when reaching out to my XML configuration file. The error shows:
[2023-10-14 09:09:15.071] [000d]   Timeout waiting for WinSCP to respond - asking for callstack
[2023-10-14 09:09:15.086] [000d]   ExeSessionProcess.RequestCallstack entering
[2023-10-14 09:09:41.150] [000d]     Exception: System.Threading.WaitHandleCannotBeOpenedException: No handle of the given name exists.
Has anyone had to deal with this before? I am not sure what to do next.
Thank you
Description: Successful log this morning, Friday Oct 20th
Description: Failed Log on Saturday Oct 14th
Autocp
Provided successful and failed debug logs
Thank you for your response!
I realized the debug file I uploaded before was for a slightly different process. So I have updated the debug logs, making sure it is consistent with the PowerShell code and transcript I have provided. I have also provided a successful debug log for comparison.
Autocp
Re: Provided successful and failed debug logs
In the PowerShell script, I put
This was to set the timeout to 10 minutes. May you confirm that I did that correctly? I am having trouble finding examples to make sure.
I suspect the failure is being caused by overload.
Any other tips to make this more resilient? Unfortunately, I am sharing the local server with another IT vendor so the processing may still be an issue going forward.
In your script, you are setting SessionOption.Timeout.
I was suggesting you to set Session.Timeout:
$session.Timeout = New-TimeSpan -Minutes 10
Ah! I missed that there was another command. Below is the altered section of the powershell script.
Unless there is any other features to add resilience, I'm thinking I will have to keep an eye on it until we deal with the overloading issue.
Thank you for your help!
