Which command WinSCP uses to set times?
bgeneto
Brazil
I'm trying to get rid of the following error dialog while performing the Synchronize command:
scp: <filename>: set times: Operation not permitted
Since I'm not the owner of the files (but still have group write permissions), I've added the CAP_FOWNER capability to the touch executable in other to fix the set time permission issue. It works as expected, meaning I can change the timestamps using the touch command like this:
touch -a -m -t "[[CC]YY]MMDDhhmm[.ss]" <filename>
But, unfortunately, WinSCP seems to be not using the touch command to 'set times' because the annoying error still persists. Is there any config that I can change in order to force WinSCP to use the touch command (in Linux remotes, of course)? Any ideas/workarounds?
Regards.
PS.: Although I've previously removed the "Preserve timestamp" setting, we all know that this flag is imposed throughout the sync process.
Re: Which command WinSCP uses to set times?
It's the remote scp process/command that sets the timestamps.
Btw, you can turn off "Preserve timestamps" even with synchronization, if you remove "Modification time" from comparison criteria.
