When I create folders and files using PHP, they do not appear in winSCP
Poul
Hi
When I create folders and files using PHP, they do not appear in WinSCP. They are there, since I can see, delete, access them etc, using PHP, but not from WinSCP.
It doesn't really matter to me, since I don't want my users to see them anyways, but I thought you should know.
Apart from that, thanks for a very nice and good program.
Best regards
Poul
Re: When I create folders and files using PHP, they do not appear in winSCP
Did you Refresh the panel after you have created the files?
If the files still do not appear after the refresh, please attach a full session log file showing the problem (using the latest version of WinSCP).
