Directories are not created correctly when moving synchronously
This is a problem when moving directories synchronously.
Suppose you have a directory structure like the one below.
At this time, if there is no folder on the local side when moving from
A →A1 B →B1 →→B2
A1
to B2
, a folder will be automatically created, but the folder will be created in a different location or the directory to be moved synchronously. It will be different
