Error code: 4 CreateFile() Win32 Error: 32
rsford31
Hi, I've seen alot of posts regarding error code 4, but this seems related to uploading files. I have a client who is using WinSCP to download files.
Cannot open remote file "/filepath/filename"
Error code: 4
Error message from server (en): The requested file can not be opened. Unexpected error. CreateFile(): Win32 Error: 32
Common reasons for the Error code 4 are:
- Renaming a file to a name of already existing file.
- Creating a directory that already exists.
- Moving a remote file to a different filesystem (HDD).
- Uploading a file to a full filesystem (HDD).
- Exceeding a user disk quota.
In the SSH server logs, I simply see OpenFile() failed. Error = 32
It says it can't open the file, but yet when I search on Win32 Error: 32 I see the definition is "The process cannot access the file because it is being used by another process". I checked the logs to see if maybe the file was being uploaded to the server the same time as they were trying to download the files. The file was uploaded to the server at 03:46 CT. The client was downloading at 07:33 CT so that isn't the case.
I checked the SSH logs and don't see more than one connection at the same time so it's not the case of two different users downloading the same file.
The SFTP server is Windows and the client computer is also Windows.
Any ideas?
Re: Error code: 4 CreateFile() Win32 Error: 32
This is not really a WinSCP question.
Anyway, is the problem intermittent or permanent? Can you delete/move/edit/whatever the file when logged in directly to the server (not via SFTP)? Did you try turning off server antivirus temporarily?
rsford31
The client says it is intermittent. I see from the logs they are downloading multiple files and then get the error. The error happened twice for one file (they eventually were able to download) and is happening 20 times for the other. They are all zip files containing a various number of reports that were generated out of their financial system.
They are using WinSCP, but have asked them to try with another FTP client. I have a test SFTP account where I copied 400+ files from their folder over to my test folder (so yes, can move the folder) and downloaded multiple times without issue, including they one they have attempted to download 20 times. This was on the 24th. I was also able to open the zipped file without issue, so it's not corrupt. I was also able to delete all the files from my test folder.
I am also using WinSCP (5.21.8). From the logs they are using 6.1.1.
I will ask that they try without their antivirus and that they try with another FTP client.
Really a WinSCP question. Thats proof:
General error (server must provide error description).
Error code: 4
Error message from server: Failure
Common causes for error code 4:
- Changing file name to one that already exists.
- Moving file on server to another file system (HDD).
- Sending file to full file system (HDD).
- Exceeding allocated disk space limit.
But problem is: remote servers are ok, and problem with WinSCP handshaking with them
But problem is: remote servers are ok, and problem with WinSCP handshaking with them@
That's it. Last sentence in the previous post.
My own ftp script works ok but sometimes I need GUI.
Sounds like @I need your pants, your boots and your motorcycle@
But i'll send WinSCP session log from tomorrow night.
Thanks you for your cooperation
Anonymous wrote:
Wrong log file, sorry. File in attachment (part of log with error)
Hi, I am waiting for answer
Stay in touch
