WinSCP not in program list
sg08234
Germany - Berlin
I do not find WinSCP (installed version 6.1.1) in the list of programs via:
Get-WmiObject -Class Win32_Product
or
Get-ItemProperty HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\*
but it is in system control | programs and functions.
I need PowerShell access to this information. What can I do?
Thanks – Michael
Re: WinSCP not in program list
The Win32_Product contains only applications installed with Windows Installer.
You have to use WinSCP MSI installer to be able to query the installation via Win32_Product.
https://winscp.net/eng/docs/installation#msi
Regarding the registry query: WinSCP installer is 32-bit. So (assuming you are on Windows 64-bit) you need to query HKLM:\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\*
Both is covered in
See also Please Stop Using Win32_Product To Find Installed Software. Alternatives Inside! | xkln.net
sg08234
Germany - Berlin
Solved: WinSCP not in program list
Thanks! There was an error in my procedure: I did not search via wildcard in HKLM:\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\* (-like WinSCP instead of -like WinSCP*)
Also many thanks for excellent link "Please Stop Using Win32_Product To Find Installed Software."
Case can be closed
Michael
