Version of .NET 4.0 assembly
WolfgangHG
just noticed that the .NET6 version of the assembly has a version of 6.1.1, while the .NET4 version has a version of 1.14.0.13736, and just declares a AssemblyInformationalVersion("6.1.1.0") attribute. Is this difference in versioning intentional? It irritated me slightly ;-).
I used the NuGet package.
Bet regards
Wolfgang
Re: Version of .NET 4.0 assembly
Not sure what you mean by .NET 6 version.
There are .NET Framework 4.0 and .NET Standard 2.0 versions.
In the current WinSCP 6.1.1 release, both have version 1.14 and product version 6.1.1.
If you see any other numbers, please post some evidence (e.g. a screenshot).
WolfgangHG
Yes, you are right, sorry. I think I got confused because I looked at the versions of WinSCP.exe (having enabled File version and Product version columns in Windows Explorer).
Forget about this post!
Wolfgang
