Cloudflare's Warp terminates WinSCP's connection to the server.
cheonmu
Hello.
I normally use Cloudflare's Warp (https://1.1.1.1/) application.
And when I connect to the server using WinSCP with Warp running, the server connection is randomly terminated.
I have enabled logging to check this issue, but nothing is logged.
. 2023-08-18 20:12:12.836 ..;d;0;2023-08-18T03:09:08.000Z;4;"root" [0];"root" [0];rwxr-xr-x;0
. 2023-08-18 20:12:12.836 xmlrpc.php;-;3236;2023-08-09T06:41:50.000Z;4;"www-data" [33];"www-data" [33];rw-r--r--;0
. 2023-08-18 20:12:12.863 Startup conversation with host finished.
. 2023-08-18 20:15:41.924 Remote side unexpectedly closed network connection
Can you someone provide me with a solution to this issue? Thank you.
Re: Cloudflare's Warp terminates WinSCP's connection to the server.
This rather looks like question that should be asked at Cloudflare's support.
