Put *.xls Also Uploads .xlsM File
Robot_1X
put "C:\Users\OSVAdmin\Documents\OSV Template\"*.xls /
This line uploads my .xls files just fine, but it also uploads the .xlsm file that resides in the OSV Template folder. Unfortunately, I cannot just move the .xlsm file to a different folder because an Excel spreadsheet I use for work needs it in this folder.
Does anyone have any suggestions on how I can prevent the .xlsm file from being uploaded?
Re: Put *.xls Also Uploads .xlsM File
I cannot reproduce the problem.
Strange. I've tried the same command as you with the same files, and only xls files are transferred.
Ok, so I've found that on other drive, I get the same behavior as you. It turned out that there's a volume setting that affects this.
See Windows wildcards with files having more than 3 characters extensions
(I've posted my own answer there too).
So either change the volume settings.
Or you can fix it by using a file mask filter:
put -filemask=*.xls "C:\Users\OSVAdmin\Documents\OSV Template\*" /
The filemask in -filemask is evaluated by WinSCP, what is independent to the volume settings. While the mask in the source parameter is evaluated by the Windows, what is affected by the volume settings.
