Time out
JackLKemp
Time out
Getting a timeout
Lost connection. Timeout detected. (data connection) Copying files to remote side failed. Copying files to remote side failed.
Attached debug XML file.
Re: Time out
Does the connection work anyhow? In WinSCP GUI? In any other client?
JackLKemp
The connection works with several other clients, and I can connect with the GUI. The version of WinSCP is 5.15.9. The Debug.xml file is the result of setting the SessionLogPath.
The log you have posted in result of setting Session.DebugLogPath, not Session.SessionLogPath.
Please post GUI log too.
Unfortunately, I have not been able to get this to work. I put the SessionLogPath in right before I do the session open, and regardless of what it gets set to (directory, directory with file that exists, directory with file that doesn't exist), it never gets written to.
The SessionLogPath should be set to a path to a file, not to a path to a folder. The same way as DebugLogPath (which you made working). If you still have problems, please post a code that shows how you set both properties (with SessionLogPath not working and DebugLogPath working).
public void Connect()
    try
        Protocol protocol;
        string ShiftedType = FtpType.ToUpper();
        if (ShiftedType.Contains("SFTP"))
            protocol = Protocol.Sftp;
        else
            if (ShiftedType.Contains("FTP"))
                protocol = Protocol.Ftp;
            else
                if (ShiftedType.Contains("SCP"))
                    protocol = Protocol.Scp;
                else
                    if (ShiftedType.Contains("WEBDAV"))
                        protocol = Protocol.Webdav;
                    else
                        protocol = Protocol.S3;
        SessionOptions options = new SessionOptions
            Protocol = protocol,
            HostName = Server,
            UserName = UserName,
            Password = Password
        if (protocol == Protocol.Sftp)
            options.SshHostKeyFingerprint = EncryptionKey;
        if (protocol == Protocol.Webdav)
            options.RootPath = RemoteDirectory.StartsWith("/") ? RemoteDirectory : "/" + RemoteDirectory;
            options.Secure = true;
        else
            options.FtpMode = FtpMode.Active;
            options.PortNumber = Port;
        TransferOptions = new TransferOptions()
            TransferMode = TransferMode.Binary,
            FilePermissions = null,
            PreserveTimestamp = false
        if(Debug)
            Session.DebugLogLevel = 1;
            Session.SessionLogPath = Path.Combine(LocalDirectory, "Session.xml");
        Session.Open(options);
    catch (Exception ex)
        throw ex;
public void DoFtp()
    try
        if (Debug)
            if (Session != null)
                if (Session.Opened)
                    Session.Close();
        LogWriter writer = new LogWriter()
            JobName = this.JobName,
            ConnectionString = this.ConnectionString,
            LogMessage = "Connecting to " + Server + "..."
        if (!Session.Opened)
            Connect();
        else
            writer.LogMessage = "Session already connected. Closing...";
            writer.WriteLog();
            Session.Close();
            writer.LogMessage = "Session closed. Connecting...";
            writer.WriteLog();
            Connect();
        writer.LogMessage = "Connected";
        writer.WriteLog();
        RemoteFileExists = Session.FileExists(RemoteDirectory.Length > 0 ? RemoteDirectory + RemoteFile : RemoteFile);
        TransferOperationResult transferOperation = null;
        switch (FtpCommand.ToUpper())
            case "GET":
                FileCount = 1;
                if (RemoteFileExists)
                    writer.LogMessage = "Getting File " + RemoteFile;
                    writer.WriteLog();
                    transferOperation = Session.GetFiles(RemoteFile, LocalDirectory, false, TransferOptions);
                else
                    if (GetFileCount() == 0)
                        writer.LogMessage = "No file exists";
                        writer.WriteLog();
                        ExceptionWriter ew = new ExceptionWriter()
                            ConnectionString = writer.ConnectionString,
                            JobName = JobName,
                            ErrorCode = 50000,
                            ErrorDescription = "No files were available",
                            Source = "FTP GET",
                            Target = "SCR FTP"
                        ew.WriteException();
                        return;
                    else
                        writer.WriteLog();
                break;
            case "MGET":
                FileCount = GetFileCount();
                if (FileCount > 0)
                    writer.LogMessage = "Getting Files " + RemoteFile;
                    writer.WriteLog();
                else
                    writer.WriteLog();
                        JobName = JobName,
                        ErrorCode = 50000,
                        Source = "FTP MGET",
                        Target = "SCR FTP"
                    return;
                break;
            case "PUT":
                string[] PutFiles = Directory.GetFiles(LocalDirectory, WildCard);
                FileCount = PutFiles.Length;
                if (PutFiles.Length > 0)
                    writer.LogMessage = "Putting File " + LocalFile;
                    writer.WriteLog();
                    foreach (string put in PutFiles)
                        string strFileName = put.Substring(put.LastIndexOf("\\") + 1);
                        if (Session.FileExists(WildCard) && !AppendIfExists)
                            transferOperation = Session.PutFiles(put, RemoteDirectory.Length > 0 ? RemoteDirectory + strFileName : strFileName, false, TransferOptions);
                            if (RemoteDirectory.Length > 0)
                                writer.LogMessage = "Put " + put + " on " + Server + " in " + RemoteDirectory;
                                writer.WriteLog();
                            else
                                writer.LogMessage = "Put " + put + " on " + Server + " in /";
                                writer.WriteLog();
                        else
                            if (AppendIfExists && Session.FileExists(WildCard))
                                TransferOptions.OverwriteMode = OverwriteMode.Append;
                                    writer.LogMessage = "Appending " + put + " on " + Server + " in " + RemoteDirectory;
                                    writer.WriteLog();
                                else
                                    writer.LogMessage = "Appending " + put + " on " + Server + " in /";
                                    writer.WriteLog();
                            else
                                if (!Session.FileExists(WildCard))
                                        writer.WriteLog();
                                    else
                                        writer.WriteLog();
                else
                    writer.LogMessage = "File " + LocalFile + " does not exist.";
                    writer.WriteLog();
                        JobName = JobName,
                        ErrorCode = 50000,
                        Source = "FTP PUT",
                        Target = "SCR FTP"
                    return;
                break;
            case "MPUT":
                string[] FilesToPut = Directory.GetFiles(LocalDirectory, WildCard);
                FileCount = FilesToPut.Length;
                if (FilesToPut.Length > 0)
                    writer.LogMessage = "Putting Files " + LocalFile;
                    writer.WriteLog();
                    foreach (string put in FilesToPut)
                        if (Session.FileExists(strFileName) && !AppendIfExists || !Session.FileExists(strFileName))
                                writer.WriteLog();
                            else
                                writer.WriteLog();
                        else
                            if (!Session.FileExists(strFileName))
                                    writer.WriteLog();
                                else
                                    writer.WriteLog();
                else
                    writer.WriteLog();
                        JobName = JobName,
                        ErrorCode = 50000,
                        Source = "FTP MPUT",
                        Target = "SCR FTP"
                    return;
                break;
        if (transferOperation != null)
            transferOperation.Check();
        writer.LogMessage = "Operation Complete";
        writer.WriteLog();
        string[] FileArray = Directory.GetFiles(LocalDirectory, WildCard);
        string MultipleFiles = string.Empty;
        if (FileArray.Length == 1)
            MultipleFiles = " file";
        else
            if (FileArray.Length == 0)
                MultipleFiles = " files";
                    JobName = JobName,
                    ErrorCode = 50000,
                    Source = "FTP PUT",
                    Target = "SCR FTP"
                return;
            else
        string Action = string.Empty;
        if (FtpCommand.ToUpper().Contains("GET"))
            Action = "Retrieved ";
        else
            Action = "Sent ";
        writer.LogMessage = Action + FileArray.Length + " " + MultipleFiles + "...";
        writer.WriteLog();
        throw ex;
and the calling code:
string strEncryptionKey = string.Empty;
string strFtpCommand = string.Empty;
string strRemoteDirectory = string.Empty;
string strLocalDirectory = string.Empty;
string strServer = string.Empty;
string strUserName = string.Empty;
string strPassword = string.Empty;
string strFileName = string.Empty;
string strFtpType = string.Empty;
string strJobName = string.Empty;
string strLocalFile = string.Empty;
string strRemoteFile = string.Empty;
string strWildCard = string.Empty;
bool bParsed = false;
string strExecutablePath = string.Empty;
string strArchiveDirectory = string.Empty;
string strFileDate = string.Empty;
string strDateFormat = string.Empty;
string strCopyFileDestination = string.Empty;
try
    Variables requiredVariables = null;
    Dts.VariableDispenser.LockOneForRead("User::FtpPort", ref requiredVariables);
    bParsed = Int16.TryParse(requiredVariables["User::FtpPort"].Value.ToString(), out Int16 nPort);
    if (!bParsed)
        nPort = 0;
    Dts.VariableDispenser.LockOneForRead("$Package::JobName", ref requiredVariables);
    strJobName = requiredVariables["$Package::JobName"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::EncryptionKey", ref requiredVariables);
    strEncryptionKey = requiredVariables["User::EncryptionKey"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::FtpServer", ref requiredVariables);
    strServer = requiredVariables["User::FtpServer"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::FtpCommand", ref requiredVariables);
    strFtpCommand = requiredVariables["User::FtpCommand"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::FtpTypeName", ref requiredVariables);
    strFtpType = requiredVariables["User::FtpTypeName"].Value.ToString();
    string strFtpTypeMin = string.Empty;
    strFtpTypeMin = strFtpType.Length > 4 ? strFtpType.Substring(0, 4).ToUpper() : "FTP";
    Dts.VariableDispenser.LockOneForRead("User::RemoteDirectory", ref requiredVariables);
    strRemoteDirectory = requiredVariables["User::RemoteDirectory"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::LocalDirectory", ref requiredVariables);
    strLocalDirectory = requiredVariables["User::LocalDirectory"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::FtpUserName", ref requiredVariables);
    strUserName = requiredVariables["User::FtpUserName"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::FtpPassword", ref requiredVariables);
    strPassword = requiredVariables["User::FtpPassword"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::FileName", ref requiredVariables);
    strFileName = requiredVariables["User::FileName"].Value.ToString();
    strWildCard = strFileName.Replace("(period)", "*");
    strLocalFile = strLocalDirectory.Length > 0 ? strLocalDirectory + "\\" + strFileName : strFileName;
    strRemoteFile = strRemoteDirectory.Length > 0 ? strRemoteDirectory + "/" + strFileName : strFileName;
    Dts.VariableDispenser.LockOneForRead("User::DeleteAfterFtp", ref requiredVariables);
    bParsed = bool.TryParse(requiredVariables["User::DeleteAfterFtp"].Value.ToString(), out bool bDeleteAfterFTP);
    bDeleteAfterFTP = bParsed && bDeleteAfterFTP;
    Dts.VariableDispenser.LockOneForRead("User::ArchiveFile", ref requiredVariables);
    bParsed = bool.TryParse(requiredVariables["User::ArchiveFile"].Value.ToString(), out bool bArchiveAfterFTP);
    bArchiveAfterFTP = bParsed && bArchiveAfterFTP;
    Dts.VariableDispenser.LockOneForRead("User::ArchiveDirectory", ref requiredVariables);
    strArchiveDirectory = requiredVariables["User::ArchiveDirectory"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::AddDateToFile", ref requiredVariables);
    bParsed = bool.TryParse(requiredVariables["User::AddDateToFile"].Value.ToString(), out bool bAddDateToFileName);
    bAddDateToFileName = bParsed && bAddDateToFileName;
    Dts.VariableDispenser.LockOneForRead("User::FtpFileDateFormat", ref requiredVariables);
    strDateFormat = requiredVariables["User::FtpFileDateFormat"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::MoveFile", ref requiredVariables);
    bParsed = bool.TryParse(requiredVariables["User::MoveFile"].Value.ToString(), out bool bMoveFilesAfterImport);
    bMoveFilesAfterImport = bParsed && bMoveFilesAfterImport;
    Dts.VariableDispenser.LockOneForRead("User::FileDestination", ref requiredVariables);
    string strFileDestination = requiredVariables["User::FileDestination"].Value.ToString();
    if (!strLocalDirectory.EndsWith("\\") && strLocalDirectory.Length > 0) strLocalDirectory += "\\";
    if (!strRemoteDirectory.EndsWith("/") && strRemoteDirectory.Length > 0) strRemoteDirectory += "/";
    Dts.VariableDispenser.LockOneForRead("User::ArchiveRetainDays", ref requiredVariables);
    bParsed = Int16.TryParse(requiredVariables["User::ArchiveRetainDays"].Value.ToString(), out Int16 nArchiveRetainDays);
    if (!bParsed)
        nArchiveRetainDays = 0;
    Dts.VariableDispenser.LockOneForRead("User::MaxArchiveCopies", ref requiredVariables);
    bParsed = Int16.TryParse(requiredVariables["User::MaxArchiveCopies"].Value.ToString(), out Int16 nMaxArchiveCount);
    if (!bParsed)
        nMaxArchiveCount = 0;
    Dts.VariableDispenser.LockOneForRead("User::AppendIfExists", ref requiredVariables);
    bParsed = bool.TryParse(requiredVariables["User::AppendIfExists"].Value.ToString(), out bool bAppendIfExists);
    bAppendIfExists = bParsed && bAppendIfExists;
    Dts.VariableDispenser.LockOneForRead("User::CopyFile", ref requiredVariables);
    bParsed = bool.TryParse(requiredVariables["User::CopyFile"].Value.ToString(), out bool bCopyFile);
    bCopyFile = bParsed && bCopyFile;
    Dts.VariableDispenser.LockOneForRead("User::CopyFileDestination", ref requiredVariables);
    strCopyFileDestination = requiredVariables["User::CopyFileDestination"].Value.ToString();
    Dts.VariableDispenser.LockOneForRead("User::ArchiveFileWithTimeStamp", ref requiredVariables);
    bParsed = bool.TryParse(requiredVariables["User::ArchiveFileWithTimeStamp"].Value.ToString(), out bool bArchiveFileWithTimestamp);
    bArchiveFileWithTimestamp = bParsed && bArchiveFileWithTimestamp;
    bool bDateAdded = true;
    if (strFtpCommand.ToUpper().Contains("PUT") && bAddDateToFileName)
        LogWriter logWriter = new LogWriter()
            ConnectionString = Dts.Connections[0].ConnectionString,
            JobName = strJobName,
            LogMessage = "Updating file names"
        CExceptionRetry retry = new CExceptionRetry()
            Function = logWriter.WriteLog,
            AutoIncreaseTimeDelay = true,
            IsTransient = true,
            MaximumRetries = 3,
            TimeDelay = 60,
            ReportConnectionString = Dts.Connections[0].ConnectionString
        retry.Retry();
        Ftp ftpRename = new Ftp()
            ConnectionString = logWriter.ConnectionString,
            DateAdded = bDateAdded,
            LocalDirectory = strLocalDirectory,
            RemoteDirectory = strRemoteDirectory,
            LocalFile = strLocalFile,
            RemoteFile = strWildCard,
            AddDateToFileName = bAddDateToFileName,
            DateFormat = strDateFormat,
            FileName = strFileName,
            Server = strServer,
            Port = nPort,
            UserName = strUserName,
            Password = strPassword,
            FtpCommand = strFtpCommand,
            FtpType = strFtpType,
            WildCard = strWildCard,
            EncryptionKey = strEncryptionKey,
            ArchiveFileWithTimestamp = bArchiveFileWithTimestamp
            IsTransient = true,
            MaximumRetries = 3,
            TimeDelay = 60,
            ReportConnectionString = Dts.Connections[0].ConnectionString,
            Function = ftpRename.AddDateToFile
        retry.Retry();
        bDateAdded = ftpRename.DateAdded;
        LogMessage = "Setting FTP options"
    CExceptionRetry cExcpetionRetry = new CExceptionRetry()
        Function = writer.WriteLog,
        IsTransient = true,
        MaximumRetries = 3,
        TimeDelay = 60,
    cExcpetionRetry.Retry();
    writer.LogMessage = "Beginning FTP...";
    Ftp ftpMain = new Ftp()
        AppendIfExists = bAppendIfExists,
        Archive = bArchiveAfterFTP,
        ArchiveFileWithTimestamp = bArchiveFileWithTimestamp,
        Server = strServer,
        Port = nPort,
        Debug = true
    cExcpetionRetry.Function = ftpMain.DoFtp;
    writer.LogMessage = "FTP Complete.";
    cExcpetionRetry.Function = writer.WriteLog;
    if (ftpMain.FileCount > 0)
        if (bArchiveAfterFTP && strArchiveDirectory.Length > 0 && Directory.Exists(strArchiveDirectory))
            writer.LogMessage = "Archiving files...";
            ftpMain.ArchiveDirectory = strArchiveDirectory;
            ftpMain.ArchiveRetainDays = nArchiveRetainDays;
            ftpMain.MaximumArchiveCopies = nMaxArchiveCount;
            cExcpetionRetry.Function = ftpMain.ArchiveFiles;
            writer.LogMessage = "Archive complete.";
        List<string> lstNewFileNames = new List<string>();
        if ((bAddDateToFileName || strFileName.Contains("(period)")) && !strFtpCommand.ToUpper().Contains("PUT"))
            ftpMain.AddDateToFileName = bAddDateToFileName;
            ftpMain.LocalDirectory = strLocalDirectory;
            ftpMain.DateFormat = strDateFormat;
            cExcpetionRetry.Function = ftpMain.AddDateToFile;
            lstNewFileNames = ftpMain.NewFileNames;
        if (bCopyFile && strCopyFileDestination.Length != 0 && Directory.Exists(strCopyFileDestination))
            string[] FilesToCopy = Directory.GetFiles(strLocalDirectory, strWildCard);
            if (FilesToCopy.Length > 0)
                writer.LogMessage = "Copying files to " + strCopyFileDestination;
                writer.WriteLog();
                foreach (string strCopyFile in FilesToCopy)
                    string strCopyName = strCopyFile.Substring(strCopyFile.LastIndexOf("\\") + 1);
                    if (File.Exists(Path.Combine(strCopyFileDestination, strCopyName)))
                        writer.LogMessage = "Deleting duplicate file (" + strCopyName + ")";
                        writer.WriteLog();
                        File.Delete(Path.Combine(strCopyFileDestination, strCopyName));
                        writer.LogMessage = "File " + Path.Combine(strCopyFileDestination, strCopyName) + " was deleted.";
                        writer.WriteLog();
                    File.Copy(strCopyFile, Path.Combine(strCopyFileDestination, strCopyName));
                    writer.LogMessage = strCopyFile + " copied to " + strCopyFileDestination;
                    writer.WriteLog();
        if (bMoveFilesAfterImport && strFileDestination.Length != 0)
            ftpMain.MoveFilesAfterImport = bMoveFilesAfterImport;
            ftpMain.FileDestination = strFileDestination;
            cExcpetionRetry.Function = ftpMain.MoveFiles;
            writer.LogMessage = "Move complete";
            if (bArchiveAfterFTP)
                if (strLocalDirectory != strFileDestination)
                    string[] arrFilesToDelete = Directory.GetFiles(strLocalDirectory, strWildCard);
                    int nFilesToDelete = arrFilesToDelete.Length;
                    if (nFilesToDelete > 0)
                        writer.LogMessage = nFilesToDelete == 1 ? "Deleting one file..." : "Deleting " + nFilesToDelete.ToString() + " files...";
                        if (arrFilesToDelete.Length > 0)
                            foreach (string strDelete in arrFilesToDelete)
                                if (File.Exists(strDelete))
                                    File.Delete(strDelete);
                        writer.LogMessage = "Delete complete.";
                    else
                        writer.LogMessage = "No files to delete. Skipping...";
        if (bDeleteAfterFTP)
                cExcpetionRetry.Function = ftpMain.DeleteFiles;
            else
    writer.LogMessage = "Session closed.";
    requiredVariables.Unlock();
    Dts.TaskResult = (int)ScriptResults.Success;
    Variables exceptionVariables = null;
        Exception = ex,
    Dts.VariableDispenser.LockOneForWrite("User::StackTrace", ref exceptionVariables);
    exceptionVariables["User::StackTrace"].Value = ex.StackTrace.Replace("\r\n", " ");
    Dts.VariableDispenser.LockOneForWrite("User::Target", ref exceptionVariables);
    exceptionVariables["User::Target"].Value = ex.TargetSite.Name;
    Dts.VariableDispenser.LockOneForWrite("User::InnerException", ref exceptionVariables);
    exceptionVariables["User::InnerException"].Value = ex.InnerException == null ? "" : ex.InnerException.StackTrace.Replace("\r\n", " ");
    Dts.VariableDispenser.LockOneForWrite("User::HelpLink", ref exceptionVariables);
    exceptionVariables["User::HelpLink"].Value = ex.HelpLink ?? "";
    exceptionVariables.Unlock();
    Dts.TaskResult = (int)ScriptResults.Failure;
You are using a (non-default) active FTP mode:
Why? That's likely the problem. Try the default passive mode.
Why? That's likely the problem. Try the default passive mode.[/quote]
I tried it with the FtpMode set to Passive and I am still getting the timeout.
  • Session.txt (114.6 KB, Private file)
There are four sessions in the log you have posted. Only the last session uses the passive mode and there's no timeout in the that session.
There is other error, but that's a different topic. It is probably caused by you trying to use Session.FileExists with a file mask. It's not possible. Instead, use Session.EnumerateRemoteFiles:
https://winscp.net/eng/docs/library_session_enumerateremotefiles
