Problem, Transferring Files via WinSCP change the last modified date.
helpuserwin2323
Hi, I noticed when I'm transferring files the date under "changed" is changing to current date when I uploaded the files, instead to keep the original date of the files.
For example the file date is 20/09/2022 5:55, but when II transfer it to my server it's changing to current time.
Is there any way to cancel the option? I want to keep the original "last modified".
Thanks in advance.
Re: Problem, Transferring Files via WinSCP change the last modified date.
Most likely the server you are connecting to or the protocol you are using does not support preserving file timestamps when uploading.
If you believe otherwise, please attach a full session log file showing the problem (using the latest version of WinSCP).
helpuserwin2323
Yeah you were right, it's not about the app. I tried to access via main account (root) with port 22, and all fine so I just got it wrong, because I used another software 'til now so I thought it might be a problem.
Thanks for your comment!
