Host is not communicating for more than 15 seconds. Still waiting...
Jajohnson@...
I cannot create a forum account it error's out no matter what I do. Jajohnson@goodwinlaw.com, Julie Johnson.
Issue is intermittent connectivity issue with WinSCP, the account has been confimed to be able to login to worldcheck site. We have been using this for year suddenly this issue. I update to the latest WinSCP v6.1.1. Thanks! Here is the issue:
1 - batch on confirm off Searching for host... Connecting to host... Host is not communicating for more than 15 seconds. Still waiting... Note: If the problem repeats, try turning off 'Optimize connection buffer size'. Warning: Aborting this operation will close connection! (A)bort (60 s): Network error: Software caused connection abort No session. C:\WorldCheck No session. No session. Non-Zero Exit Code returned from WinSCP. Check WorldCheck\SFTP sftp.world-check.com premium-world-check-day.xml.log for detailed error message
Re: Host is not communicating for more than 15 seconds. Still waiting...
Please post session log files both from working and failing session.
