Update of tunnel password
ckyr
we use a tunnel for connecting to our servers
so in the "WinSCP.ini" there are entries like:
[Sessions\kpdmdev02@DEV2]
HostName=vwcnctd02appl001
PingType=1
UserName=kpdmdev02
RemoteDirectory=/tmp/audit_manager
TunnelHostName=pdmfs1
TunnelUserName=kpdmdev02
Password=A35C7C58AAA6BAxxxxxxxxxxxxxxx6D3DEACB407D32A483548A06
[Sessions\kpdmdev02@DEV2-bld]
HostName=vwcnctd02bld001
PingType=1
UserName=kpdmdev02
RemoteDirectory=/l/pool/GRC
Password=A35C4352A4F8D2745Cxxxxxxxxxxxxxxxxxx3E30386C6C6D2F283D2E286D3DE9
whenever we the pass for user kpdmdev02 change, we have to update manually the tunnel pass via the UI, e.g. Edit ->Advanced-> Tunnel -> password -> Save
Is there any other way to change the password globally for all the entries in WinSCP.ini file?
Re: Update of tunnel password
So do you update Password or TunnelPassword?
Anyway, you can update PasswordPlain (or TunnelPasswordPlain) with a plain text password. WinSCP will encrypt them on the first run.
ckyr
Thanks Martin for your reply.
The case is how to globally change the tunnel passwords for all the entries (about 40!)
Just to change the one (in User Interface) and then copy the encrypted password to all the entries in ini file (by Notepad++ ) did not work :-(
