How to upload the last file added in the folder to the server automatically
StevenST
How to upload the last file added to the folder to the server
What command to use to allow me to upload only the last file generated, for a bat-file
I used that put -last command but it doesn't work it copies everything, I only want the last file generated.
bat - file
option batch abort
open sftp:"example of server " -privatekey="example"
put -latest C:\Users\usuario\Documents\prueba\*  /fileserver/prueba/
Re: How to upload the last file added in the folder to the server automatically
So did you try -last or -latest? It should be -latest.
https://winscp.net/eng/docs/scriptcommand_put#latest
If it does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
