Import sites from OpenSSH – quoted usernames
msmucr
when importing sites from OpenSSH (%userprofile%\.ssh\config) to WinSCP there is an issue with quotes. If particular config line has username placed between double quotes (for example - User "msmucr"), which is valid in OpenSSH config syntax, then imported profile WinSCP has incorrect username with literal quotes around.
It's a detail, but if you can strip those quotes during import, it will be great.
I'm using the latest current version – 6.1.1
Thank you very much for WinSCP!
Michal Smucr
Re: Import sites from OpenSSH – quoted usernames
I have added this issue to the tracker:
Issue 2206 – Improve OpenSSH config file parsing, particularly quoted and escaped values
Can you send me an email, so I can send you back a development version of WinSCP for testing? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
