WinSCP.SessionRemoteException Error when connecting with Server
kalyani161
I have Azure timer trigger function, which runs every 5mins and fetching the files from FTP Server. I am getting an error below error, while connecting with FTP server. I am using WinSCP 6.1.0 version
WinSCP.SessionRemoteException: Server unexpectedly closed network connection.
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
Re: WinSCP.SessionRemoteException Error when connecting with Server
Btw, you cannot get that error when connecting to FTP server. You might get it when connecting to SSH/SFTP server only. Make sure you are using the correct protocol.
