Master Password Cancel Allows Login
sneally
CA
Hi! Using Windows 10 Enterprise on both 5.21.8 and 6.1.1 versions of WinSCP. When I re-open my workspace, selecting "Cancel" within the master password prompt allows login to succeed.
Thanks,
-Scotty
I think the master password only encrypts passwords, so in case you use key based authentication the login should work without entering the master password.
Re: Master Password Cancel Allows Login
As @Guest wrote. There are also other possibilities. If you still believe the behavior is wrong, please start by posting a session log file.
