PowerShell Script Error – "SessionOptions.Protocol is Protocol.Sftp or Protocol.Scp, but SessionOpti
alkyred
USA
Trying to automate weekly FTP transfers using a powershell script. I am getting the following error:
An error occurred: Exception calling "Open" with "1" argument(s): "SessionOptions.Protocol is Protocol.Sftp or Protocol.Scp, but SessionOptions.SshHostKeyFingerprint is not set."
Here is the section of my script that seems to be the issue. It does not like
CODE
# Create session options for SFTP
    HostName = $sftpServer
    UserName = $sftpUsername
    Password = $sftpPassword
# Create session and connect
# Retrieve and set SSH host key fingerprint
$sshHostKeyFingerprint = $session.SessionOptions.HostKey.ToString()
$sessionOptions.SshHostKeyFingerprint = $sshHostKeyFingerprint
# Set transfer options to download only zip files
$transferOptions.FileMask = "*.zip"
I appreciate any help.
alkyred
USA
Re: PowerShell Script Error – "SessionOptions.Protocol is Protocol.Sftp or Protocol.Scp, but SessionOpti
Thank you martin! I am closer. Now I am getting the following:
An error occurred: Exception calling "Open" with "1" argument(s): "Connection has been unexpectedly closed. Server sent command exit status 0.
I wonder if it is because there is a banner when connecting to the site and its timing out because I cannot see the banner, therefore I cannot agree.
The banner should not be a problem. Please attach a full session log file showing the problem (using the latest version of WinSCP). If you can connect anyhow (like in the GUI), please post log for that too.
alkyred
USA
I added the following to try and generate a log file from the PowerShell script:
$session.SessionLogPath = "C:\temp\FTP.log"
But the log file is not populating.
From the GUI I get this in the log file that is attached.
Description: GUI Log
Well, you have to first create the object and only after that you can assign its properties.
alkyred
USA
I had the code in the session options section. I still do not get any logging. here is the updated code.
Todd
You have to set Session.SessionLogPath before opening the connection – before calling Session.Open. You current code throws an exception – haven't you noticed? If you haven't you probably have some bad error reporting in place.
