Troubleshooting Session Connection Failure
jay8769876
I have the following code:
# Set up session options
    Protocol = [WinSCP.Protocol]::Ftp
    HostName = $mySite
    UserName = $Userword
    Password = $Password
# Connect
Write-host $session.Output
And when I run this and see the session output I get the following:
Exception calling "Open" with "1" argument(s): "Connection failed.
Connection failed."
At line:37 char:5
+ $session.Open($sessionOptions)
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : SessionRemoteException
winscp> option batch on batch on reconnecttime 120 winscp> option confirm off confirm off winscp> option reconnecttime 120 recon
necttime 120 winscp> open "ftp://myusername:***@mysite.ca" -passive=1 -timeout=15 Connecting to mysite.ca ... Connection failed.
Timeout detected. (control connection) Connection failed. winscp> exit
Just wondering what people would recommend to troubleshoot what issue could be?
Re: Troubleshooting Session Connection Failure
Your connection details are either wrong or you do not have network connectivity to the server.
Hard to be more specific, as you didn't really tell us anything about the server, where you do the connection details from, or why you believe you should be able to connect.
Can you connect anyhow? Using WinSCP GUI? Using any other client? From any other machine? ...
