PutFileToDirectory Gives Wrong Error Message
aksarben
When I call PutFileToDirectory to a server directory that does not exist, it correctly throws an exception. However, the error message is incorrect. Here's the code:
$fullFileName = $file.fullName
if ((Test-Path -path $fullFileName -pathType leaf) -eq $false) {
   throw "File $fullFileName does not exist"
$directory = Get-PathBelowRoot -clientRoot $clientRoot -file $file
$remove = $false
$session.PutFileToDirectory($fullFileName, $directory, $remove, $options)
The directory (bib) does not exist on the server, so an exception thrown, as expected.
Here's the output:
Sending file 'C:\Users\Dick\Documents\tch\ssh\client\bib\bibliography.htm'
Write-Error: Exception calling "PutFileToDirectory" with "4" argument(s): "Cannot create remote file '/C:/Users/Dick/bib/bibliography.htm'.
No such file or directory.
Error code: 2 Error message from server: No such file"
The message clearly says I'm trying to create a server file called
/C:/Users/Dick/bib/bibliography.htm. But that's the client file being sent, not
the name of the server file which will be written.
The error message should read:
Write-Error: Exception calling "PutFileToDirectory" with "4" argument(s): "Cannot create remote file '/bib/bibliography.htm'. No such file or directory.
The server is OpenSSH Server. Is this error message coming from the server? If not, is it something you can fix?
Re: PutFileToDirectory Gives Wrong Error Message
When I try:
$session.PutFileToDirectory("C:\existing\test.txt", "/non/existing")
I get:
Exception calling "PutFileToDirectory" with "2" argument(s): "Cannot create remote file '/non/existing/test.txt'.
Error code: 2
So it behaves as expected. Please double check the paths you are passing to Session.PutFileToDirectory.
