C# SFTP Remote Side Panel
Maint Tech
united states
re: C# form VS 2013
I'm able to get the local side panel to show the actual icon for files, i.e.; pdf files show the Adobe Reader icon and docx shows the Word icon using
string[] s = Directory.GetFileSystemEntries("C:\\Shared Files");
But I'm having issues to obtain the remote side panel files to show the icons. I've already tried
NativeMethods.SHGetFileInfo(fileInfo,...
I'm sure it's something I'm overlooking. Can anyone help with a solution?
Re: C# SFTP Remote Side Panel
Well, this is not really a WinSCP question.
Anyway, WinSCP GUI also uses SHGetFileInfo to obtain icon for a given filename. So it should work, if you use the correct arguments. You can check FakeFileImageIndex function in WinSCP source code.
