Script to upload folders or files does not work
diaverso
spain
Have created with the program generator 2 scripts.
1st
@echo off
"C:\Users\SUPER\AppData\Local\Programs\WinSCP\WinSCP.com" ^
  /log="C:\ruta\editable\al\registro\WinSCP.log" /ini=nul ^
  /command ^
    "open sftp://diaverso.5633997f:pass@ip:2022/ -hostkey="""" -rawsettings FSProtocol=2" ^
    "put D:\Scripts\FTP\myscript.txt /" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
I get this result in the console, but it doesn't sync the folder
2nd
## Necesario para PowerShell 7.3 y posteriores
$PSNativeCommandArgumentPassing = "Legacy"
& "C:\Users\SUPER\AppData\Local\Programs\WinSCP\WinSCP.com" `
  /log="C:\Users\SUPER\AppData\Local\Programs\WinSCP\logWinSCP.log" /ini=nul `
  /command `
    "open sftp://diaverso.5633997f:pass@ip:2022/ -hostkey=`"`"ssh-ed25519 `"`" -rawsettings FSProtocol=2" `
    "put D:\Scripts\FTP\myscript.txt /" `
    "Su orden 2" `
    "exit"
$winscpResult = $LastExitCode
if ($winscpResult -eq 0)
  Write-Host "Success"
else
  Write-Host "Error"
exit $winscpResult
This comes out, but it doesn't upload the file
How can I fix it?
Re: Script to upload folders or files does not work
