WinSCP Disconnects from Server when Making a Folder/Directory
cuppelix1
Compton
I never tweaked any setting but while on the server if I select Create Folder an then type the name in it disconnects me. When I reconnect the folder is there, so why am I getting disconnected if the command is working?
Thanks you in advance for any help
Cupe
PS - It will also not let me enter folders on my local drive when I click on them it does nothing.
Re: WinSCP Disconnects from Server when Making a Folder/Directory
