SFTP PutFileToDirectory failing on 3rd file being transferred.
drobbins
Ontario
We have a PowerShell script that SFTP files. It transfers 2 files but consistently fails on the third file (regardless of size). I added a Start-Sleep -Seconds 25 in between each PutFileToDirectory call and it resolves it, but I don't think this is the best solution.
I attached the session log with error
Portion of the code is
# Load WinSCP .NET assembly
# Setup session options
    HostName = $HostName
    UserName = $UserName
    SshHostKeyFingerprint = $SshHostKeyFingerprint
    SshPrivateKeyPath = $SshPrivateKeyPath
    Timeout = New-TimeSpan -Seconds 60
$session.SessionLogPath = "e:\FTP\DV\Config\session.log"
$transferOptions.ResumeSupport.State = WinSCP.TransferResumeSupportState]::Off
$transferOptions.FilePermissions = $Null
$transferOptions.PreserveTimestamp = $False
#Get all files with file extension *.EFT80ST from process folder
$processFileList = Get-ChildItem -Path $FTPTransferFiles
#iterate thru each file in the list
foreach ($item in $processFileList) {
    $transferResult =
        $session.PutFileToDirectory(
            $item.FullName, $RemoteDirectory,$False, $transferOptions)
Apologize if I haven't posted a proper posting as I am new to PowerShell scripting and WINSCP
Re: SFTP PutFileToDirectory failing on 3rd file being transferred.
The error comes from the server. Please ask the server administrator, why the server cannot accept three successive uploads.
