Status Code
retlacs
Status Code
FTP is giving a status code = 2 and am not sure why?
Here is the log:
It is at this line:
< 2023-05-16 09:17:17.964 Status code: 2
2023-05-16 09:17:17.884 Script: Authenticated.
. 2023-05-16 09:17:17.884 --------------------------------------------------------------------------
. 2023-05-16 09:17:17.884 Using SFTP protocol.
. 2023-05-16 09:17:17.885 Doing startup conversation with host.
< 2023-05-16 09:17:17.885 Script: Starting the session...
> 2023-05-16 09:17:17.885 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2023-05-16 09:17:17.902 Type: SSH_FXP_VERSION, Size: 176, Number: -1
. 2023-05-16 09:17:17.902 SFTP version 6 negotiated.
. 2023-05-16 09:17:17.903 Server requests EOL sequence "\r\n".
. 2023-05-16 09:17:17.903 Server software: Cerberus FTP Server 11.1.0.0 (110100000) by Cerberus, LLC
. 2023-05-16 09:17:17.903 Server support information (supported2):
. 2023-05-16 09:17:17.903   Attribute mask: 2BD, Attribute bits: FF, Open flags: 7
. 2023-05-16 09:17:17.903   Access mask: 3, Open block vector: 0, Block vector: 0, Max read size: 0
. 2023-05-16 09:17:17.903   Attribute extensions (0)
. 2023-05-16 09:17:17.903   Extensions (2)
. 2023-05-16 09:17:17.903     check-file
. 2023-05-16 09:17:17.903     copy-file
. 2023-05-16 09:17:17.903 We will use UTF-8 strings as it is mandatory with SFTP version 4 and newer
. 2023-05-16 09:17:17.903 Getting current directory name.
. 2023-05-16 09:17:17.903 Getting real path for '.'
> 2023-05-16 09:17:17.903 Type: SSH_FXP_REALPATH, Size: 11, Number: 16
< 2023-05-16 09:17:17.922 Type: SSH_FXP_NAME, Size: 72, Number: 16
. 2023-05-16 09:17:17.923 Real path is '/'
. 2023-05-16 09:17:17.923 Startup conversation with host finished.
< 2023-05-16 09:17:17.923 Script: Session started.
< 2023-05-16 09:17:17.923 Script: Active session: [1] FRO098@ftp.glasslewis.com
> 2023-05-16 09:17:17.923 Script: put \\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098*.csv
. 2023-05-16 09:17:17.924 Copying 1 files/directories to remote directory "/" - total size: 238,997
. 2023-05-16 09:17:17.925   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2023-05-16 09:17:17.925   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2023-05-16 09:17:17.925   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2023-05-16 09:17:17.925 File: '\\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098-20230515.csv' [2023-05-16T07:25:40.635Z] [238997]
. 2023-05-16 09:17:17.927 Copying \\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098-20230515.csv to remote directory started.
. 2023-05-16 09:17:17.927 Binary transfer mode selected.
. 2023-05-16 09:17:17.927 Checking existence of file.
> 2023-05-16 09:17:17.927 Type: SSH_FXP_LSTAT, Size: 33, Number: 263
< 2023-05-16 09:17:17.946 Type: SSH_FXP_ATTRS, Size: 62, Number: 263
. 2023-05-16 09:17:17.946 File exists: FRO098-20230515.csv;-;238997;2023-05-16T07:25:40.000Z;4;"" [0];"" [0];rw-rw-rw-;1
. 2023-05-16 09:17:17.946 Checking existence of partially transferred file.
> 2023-05-16 09:17:17.946 Type: SSH_FXP_LSTAT, Size: 42, Number: 519
< 2023-05-16 09:17:17.964 Type: SSH_FXP_STATUS, Size: 55, Number: 519
. 2023-05-16 09:17:17.964 Opening remote file.
> 2023-05-16 09:17:17.964 Type: SSH_FXP_OPEN, Size: 51, Number: 771
< 2023-05-16 09:17:17.984 Type: SSH_FXP_HANDLE, Size: 47, Number: 771
> 2023-05-16 09:17:17.985 Type: SSH_FXP_WRITE, Size: 16379, Number: 1286
. 2023-05-16 09:17:17.992 14 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2023-05-16 09:17:17.992 Type: SSH_FXP_CLOSE, Size: 47, Number: 5124
< 2023-05-16 09:17:18.027 Type: SSH_FXP_STATUS, Size: 22, Number: 1286
< 2023-05-16 09:17:18.027 Status code: 0
< 2023-05-16 09:17:18.039 Type: SSH_FXP_STATUS, Size: 22, Number: 1542
< 2023-05-16 09:17:18.039 Status code: 0
< 2023-05-16 09:17:18.044 Type: SSH_FXP_STATUS, Size: 22, Number: 1798
< 2023-05-16 09:17:18.044 Status code: 0
< 2023-05-16 09:17:18.044 Type: SSH_FXP_STATUS, Size: 22, Number: 2054
< 2023-05-16 09:17:18.055 Type: SSH_FXP_STATUS, Size: 22, Number: 2310
< 2023-05-16 09:17:18.055 Status code: 0
< 2023-05-16 09:17:18.055 Type: SSH_FXP_STATUS, Size: 22, Number: 2566
< 2023-05-16 09:17:18.060 Type: SSH_FXP_STATUS, Size: 22, Number: 2822
< 2023-05-16 09:17:18.060 Status code: 0
< 2023-05-16 09:17:18.060 Type: SSH_FXP_STATUS, Size: 22, Number: 3078
< 2023-05-16 09:17:18.060 Type: SSH_FXP_STATUS, Size: 22, Number: 3334
< 2023-05-16 09:17:18.071 Type: SSH_FXP_STATUS, Size: 22, Number: 3590
< 2023-05-16 09:17:18.072 Status code: 0
< 2023-05-16 09:17:18.072 Type: SSH_FXP_STATUS, Size: 22, Number: 3846
< 2023-05-16 09:17:18.072 Type: SSH_FXP_STATUS, Size: 22, Number: 4102
< 2023-05-16 09:17:18.076 Type: SSH_FXP_STATUS, Size: 22, Number: 4358
< 2023-05-16 09:17:18.076 Status code: 0
< 2023-05-16 09:17:18.076 Type: SSH_FXP_STATUS, Size: 22, Number: 4614
< 2023-05-16 09:17:18.076 Type: SSH_FXP_STATUS, Size: 22, Number: 4870
< 2023-05-16 09:17:18.088 Type: SSH_FXP_STATUS, Size: 22, Number: 5124
< 2023-05-16 09:17:18.088 Status code: 0
> 2023-05-16 09:17:18.088 Type: SSH_FXP_REMOVE, Size: 29, Number: 5389
< 2023-05-16 09:17:18.108 Type: SSH_FXP_STATUS, Size: 22, Number: 5389
< 2023-05-16 09:17:18.108 Status code: 0
> 2023-05-16 09:17:18.108 Type: SSH_FXP_RENAME, Size: 66, Number: 5650
< 2023-05-16 09:17:18.198 Type: SSH_FXP_STATUS, Size: 47, Number: 5650
< 2023-05-16 09:17:18.198 Status code: 0
. 2023-05-16 09:17:18.198 Preserving timestamp [2023-05-16T07:25:40.000Z]
> 2023-05-16 09:17:18.198 Type: SSH_FXP_SETSTAT, Size: 46, Number: 1033
< 2023-05-16 09:17:18.254 Type: SSH_FXP_STATUS, Size: 22, Number: 1033
< 2023-05-16 09:17:18.254 Status code: 0
. 2023-05-16 09:17:18.254 Transfer done: '\\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098-20230515.csv' => '/FRO098-20230515.csv' [238997]
. 2023-05-16 09:17:18.255 Copying finished: Transferred: 238,997, Elapsed: 0:00:00, CPS: 722,045/s
> 2023-05-16 09:17:18.255 Script: close
. 2023-05-16 09:17:18.255 Closing connection.
. 2023-05-16 09:17:18.255 Sending special code: 1
. 2023-05-16 09:17:18.289 Main session channel closed
. 2023-05-16 09:17:18.290 All channels closed
Here is my code:
winscp.exe /hostkey=ssh-rsa 2048 17LgdjI/nxBPU6ZeYVWnbVWkKPOn11VqmGtNNRmAfzM /log=C:\Automate\Logs\D022_FTP_To_GlassLewis_%date:~-4,4%_%date:~-10,2%_%date:~7,2%.log /loglevel=0 /command "option batch abort" "option confirm off" "open sftp://<ID>:<xyz>@ftp.glasslewis.com" "put \\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098*.csv" close "exit"
if %ERRORLEVEL% equ 0 (
 echo SUCCESS
 exit /b 0
) else (
  echo ERROR FTP Problem
 exit /b 1
close "exit"
I am using the same FTP script for others but this is the only one failing with status code =2
Any help is appreciated.
retlacs
Martin,
I am hoping you can help me please.
It ran again today and the file was transferred successfully but it gave a return code 1 because of the status code = 2 on the log. Because the FTP script is giving a bad return code, the entire job is failing even though the file had been transferred. We are using WinSCP v 5.21.8 Build 13000 2023-04-11. I also tried to manually transferred file using the WinSCP GUI and no error.
Here is the log today and the error is at:
 < 2023-05-17 11:44:35.658 Status code: 2
. 2023-05-17 11:44:35.296 --------------------------------------------------------------------------
. 2023-05-17 11:44:35.297 WinSCP Version 5.21.8 (Build 13000 2023-04-11) (OS 10.0.19045 - Windows 10 Enterprise)
. 2023-05-17 11:44:35.297 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2023-05-17 11:44:35.297 Log level: Normal, Rotating after: 1G, Keeping at most 10 logs
. 2023-05-17 11:44:35.297 Local account: FRONTIER\jl
. 2023-05-17 11:44:35.297 Working directory: C:\Program Files (x86)\WinSCP
. 2023-05-17 11:44:35.297 Process ID: 716
. 2023-05-17 11:44:35.314 Ancestor processes: cmd, Code, Code, Code, explorer, ...
. 2023-05-17 11:44:35.315 Command-line: winscp.exe  /hostkey=ssh-rsa 2048 fgsgfdgfdhgfghgjghj /log=C:\Automate\Logs\D022_FTP_To_GlassLewis_2023_05_17.log /loglevel=0 /command "option batch abort" "option confirm off" "open sftp://FRO098:***@ftp.glasslewis.com/ -rawsettings FSProtocol=2" "put \\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098*.csv" close "exit"
. 2023-05-17 11:44:35.315 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/12/2023, DST End: 11/5/2023
. 2023-05-17 11:44:35.316 Login time: Wednesday, May 17, 2023 11:44:35 AM
. 2023-05-17 11:44:35.316 --------------------------------------------------------------------------
. 2023-05-17 11:44:35.316 Script: Retrospectively logging previous script records:
< 2023-05-17 11:44:35.316 Script: Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead.
. 2023-05-17 11:44:35.316 Session name: 2048 (Ad-Hoc site)
. 2023-05-17 11:44:35.316 Host name: 2048 (Port: 22)
. 2023-05-17 11:44:35.316 User name:  (Password: No, Key file: No, Passphrase: No)
. 2023-05-17 11:44:35.316 Tunnel: No
. 2023-05-17 11:44:35.316 Transfer Protocol: SFTP (SCP)
. 2023-05-17 11:44:35.316 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2023-05-17 11:44:35.316 Disable Nagle: No
. 2023-05-17 11:44:35.316 Proxy: None
. 2023-05-17 11:44:35.316 Send buffer: 262144
. 2023-05-17 11:44:35.316 Compression: No
. 2023-05-17 11:44:35.316 Bypass authentication: No
. 2023-05-17 11:44:35.316 Try agent: Yes; Agent forwarding: No; KI: Yes; GSSAPI: Yes
. 2023-05-17 11:44:35.316 GSSAPI: KEX: No; Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2023-05-17 11:44:35.316 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2023-05-17 11:44:35.316 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2023-05-17 11:44:35.316 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2023-05-17 11:44:35.316 Simple channel: Yes
. 2023-05-17 11:44:35.316 Return code variable: Autodetect; Lookup user groups: Auto
. 2023-05-17 11:44:35.316 Shell: default
. 2023-05-17 11:44:35.316 EOL: LF, UTF: Auto
. 2023-05-17 11:44:35.316 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2023-05-17 11:44:35.316 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2023-05-17 11:44:35.316 SFTP Bugs: Auto,Auto
. 2023-05-17 11:44:35.316 SFTP Server: default
. 2023-05-17 11:44:35.316 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2023-05-17 11:44:35.316 Cache directory changes: Yes, Permanent: Yes
. 2023-05-17 11:44:35.316 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2023-05-17 11:44:35.316 DST mode: Unix
< 2023-05-17 11:44:35.316 Script: Searching for host...
. 2023-05-17 11:44:35.317 Looking up host "2048" for SSH connection
. 2023-05-17 11:44:35.317 Connecting to 0.0.8.0 port 22
. 2023-05-17 11:44:35.320 Failed to connect to 0.0.8.0: Network error: Network is unreachable
< 2023-05-17 11:44:35.320 Script: Network error: Network is unreachable
. 2023-05-17 11:44:35.322 --------------------------------------------------------------------------
. 2023-05-17 11:44:35.322 WinSCP Version 5.21.8 (Build 13000 2023-04-11) (OS 10.0.19045 - Windows 10 Enterprise)
. 2023-05-17 11:44:35.322 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2023-05-17 11:44:35.322 Log level: Normal, Rotating after: 1G, Keeping at most 10 logs
. 2023-05-17 11:44:35.322 Local account: XYZ\jl
. 2023-05-17 11:44:35.322 Working directory: C:\Program Files (x86)\WinSCP
. 2023-05-17 11:44:35.322 Process ID: 716
. 2023-05-17 11:44:35.322 Ancestor processes: cmd, Code, Code, Code, explorer, ...
. 2023-05-17 11:44:35.323 Command-line: winscp.exe  /hostkey=ssh-rsa 2048 sflasjfkajfalksdjldf /log=C:\Automate\Logs\D022_FTP_To_GlassLewis_2023_05_17.log /loglevel=0 /command "option batch abort" "option confirm off" "open sftp://FRO098:***@ftp.glasslewis.com/ -rawsettings FSProtocol=2" "put \\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098*.csv" close "exit"
. 2023-05-17 11:44:35.323 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/12/2023, DST End: 11/5/2023
. 2023-05-17 11:44:35.323 Login time: Wednesday, May 17, 2023 11:44:35 AM
. 2023-05-17 11:44:35.323 --------------------------------------------------------------------------
. 2023-05-17 11:44:35.323 Script: Retrospectively logging previous script records:
. 2023-05-17 11:44:35.324 Script: Failed
> 2023-05-17 11:44:35.324 Script: option batch abort
< 2023-05-17 11:44:35.324 Script: batch           abort
> 2023-05-17 11:44:35.324 Script: option confirm off
< 2023-05-17 11:44:35.324 Script: confirm         off
> 2023-05-17 11:44:35.324 Script: open sftp://uid:***@ftp.glasslewis.com/ -rawsettings FSProtocol=2
. 2023-05-17 11:44:35.324 --------------------------------------------------------------------------
. 2023-05-17 11:44:35.324 Session name: uid@ftp.glasslewis.com (Ad-Hoc site)
. 2023-05-17 11:44:35.324 Host name: ftp.glasslewis.com (Port: 22)
. 2023-05-17 11:44:35.324 User name: uid (Password: Yes, Key file: No, Passphrase: No)
. 2023-05-17 11:44:35.324 Tunnel: No
. 2023-05-17 11:44:35.324 Transfer Protocol: SFTP
. 2023-05-17 11:44:35.324 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2023-05-17 11:44:35.324 Disable Nagle: No
. 2023-05-17 11:44:35.324 Proxy: None
. 2023-05-17 11:44:35.324 Send buffer: 262144
. 2023-05-17 11:44:35.324 Compression: No
. 2023-05-17 11:44:35.324 Bypass authentication: No
. 2023-05-17 11:44:35.324 Try agent: Yes; Agent forwarding: No; KI: Yes; GSSAPI: Yes
. 2023-05-17 11:44:35.324 GSSAPI: KEX: No; Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2023-05-17 11:44:35.324 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2023-05-17 11:44:35.324 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2023-05-17 11:44:35.324 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2023-05-17 11:44:35.324 Simple channel: Yes
. 2023-05-17 11:44:35.324 Return code variable: Autodetect; Lookup user groups: Auto
. 2023-05-17 11:44:35.324 Shell: default
. 2023-05-17 11:44:35.324 EOL: LF, UTF: Auto
. 2023-05-17 11:44:35.324 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2023-05-17 11:44:35.324 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2023-05-17 11:44:35.324 SFTP Bugs: Auto,Auto
. 2023-05-17 11:44:35.324 SFTP Server: default
. 2023-05-17 11:44:35.324 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2023-05-17 11:44:35.324 Cache directory changes: Yes, Permanent: Yes
. 2023-05-17 11:44:35.324 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2023-05-17 11:44:35.324 DST mode: Unix
< 2023-05-17 11:44:35.324 Script: Searching for host...
. 2023-05-17 11:44:35.325 Looking up host "ftp.glasslewis.com" for SSH connection
. 2023-05-17 11:44:35.332 Connecting to 40.67.156.136 port 22
. 2023-05-17 11:44:35.349 Connected to 40.67.156.136
< 2023-05-17 11:44:35.349 Script: Connecting to host...
. 2023-05-17 11:44:35.349 We claim version: SSH-2.0-WinSCP_release_5.21.8
. 2023-05-17 11:44:35.365 Remote version: SSH-2.0-CerberusFTPServer_11.0 FIPS
. 2023-05-17 11:44:35.366 Using SSH protocol version 2
. 2023-05-17 11:44:35.367 Have a known host key of type rsa2
. 2023-05-17 11:44:35.384 Doing ECDH key exchange with curve nistp256 and hash SHA-256
. 2023-05-17 11:44:35.461 Host key fingerprint is:
. 2023-05-17 11:44:35.461 ssh-rsa 2048 SHA256:sfsadfsa,d;fa;lfkasl;fk
< 2023-05-17 11:44:35.461 Script: Authenticating...
. 2023-05-17 11:44:35.462 Host key matches cached key
. 2023-05-17 11:44:35.462 Initialised AES-256 SDCTR (AES-NI accelerated) [aes256-ctr] outbound encryption
. 2023-05-17 11:44:35.462 Initialised HMAC-SHA-256 outbound MAC algorithm
. 2023-05-17 11:44:35.477 Initialised AES-256 SDCTR (AES-NI accelerated) [aes256-ctr] inbound encryption
. 2023-05-17 11:44:35.478 Initialised HMAC-SHA-256 inbound MAC algorithm
! 2023-05-17 11:44:35.494 Using username "uid".
< 2023-05-17 11:44:35.494 Script: Using username "uid".
. 2023-05-17 11:44:35.511 Server offered these authentication methods: password,publickey
. 2023-05-17 11:44:35.511 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2023-05-17 11:44:35.511 Using stored password.
< 2023-05-17 11:44:35.511 Script: Authenticating with pre-entered password.
. 2023-05-17 11:44:35.511 Sent password
. 2023-05-17 11:44:35.570 Access granted
. 2023-05-17 11:44:35.571 Opening main session channel
. 2023-05-17 11:44:35.586 Opened main channel
. 2023-05-17 11:44:35.602 Started a shell/command
< 2023-05-17 11:44:35.602 Script: Authenticated.
. 2023-05-17 11:44:35.602 --------------------------------------------------------------------------
. 2023-05-17 11:44:35.602 Using SFTP protocol.
. 2023-05-17 11:44:35.603 Doing startup conversation with host.
< 2023-05-17 11:44:35.603 Script: Starting the session...
> 2023-05-17 11:44:35.603 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2023-05-17 11:44:35.619 Type: SSH_FXP_VERSION, Size: 176, Number: -1
. 2023-05-17 11:44:35.619 SFTP version 6 negotiated.
. 2023-05-17 11:44:35.619 Server requests EOL sequence "\r\n".
. 2023-05-17 11:44:35.619 Server software: Cerberus FTP Server 11.1.0.0 (110100000) by Cerberus, LLC
. 2023-05-17 11:44:35.619 Server support information (supported2):
. 2023-05-17 11:44:35.619   Attribute mask: 2BD, Attribute bits: FF, Open flags: 7
. 2023-05-17 11:44:35.619   Access mask: 3, Open block vector: 0, Block vector: 0, Max read size: 0
. 2023-05-17 11:44:35.620   Attribute extensions (0)
. 2023-05-17 11:44:35.620   Extensions (2)
. 2023-05-17 11:44:35.620     check-file
. 2023-05-17 11:44:35.620     copy-file
. 2023-05-17 11:44:35.620 We will use UTF-8 strings as it is mandatory with SFTP version 4 and newer
. 2023-05-17 11:44:35.620 Getting current directory name.
. 2023-05-17 11:44:35.620 Getting real path for '.'
> 2023-05-17 11:44:35.620 Type: SSH_FXP_REALPATH, Size: 11, Number: 16
< 2023-05-17 11:44:35.638 Type: SSH_FXP_NAME, Size: 72, Number: 16
. 2023-05-17 11:44:35.638 Real path is '/'
. 2023-05-17 11:44:35.638 Startup conversation with host finished.
< 2023-05-17 11:44:35.638 Script: Session started.
< 2023-05-17 11:44:35.638 Script: Active session: [1] uid@ftp.glasslewis.com
> 2023-05-17 11:44:35.638 Script: put \\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098*.csv
. 2023-05-17 11:44:35.640 Copying 1 files/directories to remote directory "/" - total size: 239,841
. 2023-05-17 11:44:35.640   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2023-05-17 11:44:35.640   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2023-05-17 11:44:35.640   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2023-05-17 11:44:35.640 File: '\\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098-20230516.csv' [2023-05-17T07:37:57.063Z] [239841]
. 2023-05-17 11:44:35.641 Copying "\\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098-20230516.csv" to remote directory started.
. 2023-05-17 11:44:35.641 Binary transfer mode selected.
. 2023-05-17 11:44:35.641 Checking existence of file.
> 2023-05-17 11:44:35.641 Type: SSH_FXP_LSTAT, Size: 33, Number: 263
< 2023-05-17 11:44:35.658 Type: SSH_FXP_STATUS, Size: 55, Number: 263
. 2023-05-17 11:44:35.658 Checking existence of partially transferred file.
> 2023-05-17 11:44:35.658 Type: SSH_FXP_LSTAT, Size: 42, Number: 519
< 2023-05-17 11:44:35.675 Type: SSH_FXP_STATUS, Size: 55, Number: 519
< 2023-05-17 11:44:35.675 Status code: 2
. 2023-05-17 11:44:35.675 Opening remote file.
> 2023-05-17 11:44:35.675 Type: SSH_FXP_OPEN, Size: 51, Number: 771
< 2023-05-17 11:44:35.693 Type: SSH_FXP_HANDLE, Size: 47, Number: 771
> 2023-05-17 11:44:35.693 Type: SSH_FXP_WRITE, Size: 16379, Number: 1286
. 2023-05-17 11:44:35.722 14 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2023-05-17 11:44:35.722 Type: SSH_FXP_CLOSE, Size: 47, Number: 5124
< 2023-05-17 11:44:35.752 Type: SSH_FXP_STATUS, Size: 22, Number: 1286
< 2023-05-17 11:44:35.752 Status code: 0
< 2023-05-17 11:44:35.765 Type: SSH_FXP_STATUS, Size: 22, Number: 1542
< 2023-05-17 11:44:35.765 Status code: 0
< 2023-05-17 11:44:35.780 Type: SSH_FXP_STATUS, Size: 22, Number: 1798
< 2023-05-17 11:44:35.781 Status code: 0
< 2023-05-17 11:44:35.781 Type: SSH_FXP_STATUS, Size: 22, Number: 2054
< 2023-05-17 11:44:35.781 Type: SSH_FXP_STATUS, Size: 22, Number: 2310
< 2023-05-17 11:44:35.781 Type: SSH_FXP_STATUS, Size: 22, Number: 2566
< 2023-05-17 11:44:35.790 Type: SSH_FXP_STATUS, Size: 22, Number: 2822
< 2023-05-17 11:44:35.790 Status code: 0
< 2023-05-17 11:44:35.790 Type: SSH_FXP_STATUS, Size: 22, Number: 3078
< 2023-05-17 11:44:35.790 Type: SSH_FXP_STATUS, Size: 22, Number: 3334
< 2023-05-17 11:44:35.790 Type: SSH_FXP_STATUS, Size: 22, Number: 3590
< 2023-05-17 11:44:35.790 Type: SSH_FXP_STATUS, Size: 22, Number: 3846
< 2023-05-17 11:44:35.790 Type: SSH_FXP_STATUS, Size: 22, Number: 4102
< 2023-05-17 11:44:35.790 Type: SSH_FXP_STATUS, Size: 22, Number: 4358
< 2023-05-17 11:44:35.806 Type: SSH_FXP_STATUS, Size: 22, Number: 4614
< 2023-05-17 11:44:35.806 Status code: 0
< 2023-05-17 11:44:35.806 Type: SSH_FXP_STATUS, Size: 22, Number: 4870
< 2023-05-17 11:44:35.806 Type: SSH_FXP_STATUS, Size: 22, Number: 5124
> 2023-05-17 11:44:35.806 Type: SSH_FXP_RENAME, Size: 66, Number: 5394
< 2023-05-17 11:44:35.902 Type: SSH_FXP_STATUS, Size: 47, Number: 5394
< 2023-05-17 11:44:35.902 Status code: 0
. 2023-05-17 11:44:35.902 Preserving timestamp [2023-05-17T07:37:57.000Z]
> 2023-05-17 11:44:35.902 Type: SSH_FXP_SETSTAT, Size: 42, Number: 1033
< 2023-05-17 11:44:36.039 Type: SSH_FXP_STATUS, Size: 22, Number: 1033
< 2023-05-17 11:44:36.039 Status code: 0
. 2023-05-17 11:44:36.039 Transfer done: '\\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098-20230516.csv' => '/FRO098-20230516.csv' [239841]
. 2023-05-17 11:44:36.039 Copying finished: Transferred: 239,841, Elapsed: 0:00:00, CPS: 601,105/s
> 2023-05-17 11:44:36.039 Script: close
. 2023-05-17 11:44:36.039 Closing connection.
. 2023-05-17 11:44:36.039 Sending special code: 1
. 2023-05-17 11:44:36.070 Main session channel closed
. 2023-05-17 11:44:36.070 All channels closed
Here is my code:
cd C:\Program Files (x86)\WinSCP
winscp.exe /hostkey=ssh-rsa 2048 17Lasfasdgfvsdafgsdfgvsfgsdfsdgad /log=C:\Automate\Logs\D022_FTP_To_GlassLewis_%date:~-4,4%_%date:~-10,2%_%date:~7,2%.log /loglevel=0 /command "option batch abort" "option confirm off" "open sftp://<uid>:<pswd>@ftp.glasslewis.com/ -rawsettings FSProtocol=2" "put \\fcmcftp\FTP\Usr\Portia\ProxyHoldings\FRO098*.csv" close "exit"
 echo SUCCESS
 exit /b 0
) else (
 exit /b 1
close "exit"
It might be a stupid thing that I can't see but am hoping you will help me. I am new to this FTP.
Thank you.
I do not think your problem has anything to do with "Status code: 2" – That's perfectly normal.
It's rather the
That's all wrong for numerous reasons.
The hostkey should go to -hostkey switch of the open command.
https://winscp.net/eng/docs/scriptcommand_open#hostkey
Use WinSCP GUI to generate the commandline with right syntax.
https://winscp.net/eng/docs/ui_generateurl#script
