.Net Assembly SCP download to Windows always stops after476 mb
sameh
When trying to download a large file from my SCP server it always stops at 476 MB. I tried
sessionOptions.AddRawSettings("SendBuf", "0");
sessionOptions.AddRawSettings("SshSimple ", "0");
But still can't do it. Here is my code:
try
    // Setup session options
        Protocol = Protocol.Scp,
        HostName = "192.168.10.1",
        UserName = "******",
        Password = "******",
        SshHostKeyPolicy = SshHostKeyPolicy.GiveUpSecurityAndAcceptAny
    // Connect to the remote server and download files
        session.ReconnectTime = TimeSpan.FromSeconds(2);
        session.Open(sessionOptions);
        string remotePath = "/mnt/hdd_1/mstore/QLIVE.vfdp/storage/1001_NileSatDocuments_220101010000_250101120000/";
        var opts = EnumerationOptions.EnumerateDirectories | EnumerationOptions.AllDirectories;
        IEnumerable<RemoteFileInfo> fileInfos = session.EnumerateRemoteFiles(remotePath, null, opts);
        foreach (RemoteFileInfo fileInfo in fileInfos)
            if (fileInfo.IsDirectory)
                continue; // skip directories
            // Determine local and remote file paths
            string remoteFilePath = RemotePath.EscapeFileMask(fileInfo.FullName);
            string localFilePath = RemotePath.TranslateRemotePathToLocal(remoteFilePath, remotePath, Path.GetTempPath());
            // Download the file to the temporary folder
            System.Diagnostics.Debug.WriteLine("Downloading file {0}...", fileInfo.FullName);
            TransferOperationResult transferResult = session.GetFiles(remoteFilePath, localFilePath);
            // Check if download succeeded
            if (!transferResult.IsSuccess)
                System.Diagnostics.Debug.WriteLine("Error downloading file {0}: {1}", fileInfo.FullName, transferResult.Failures[0].Message);
            if (Path.GetExtension(fileInfo.Name) == ".zip")
                using (ZipFile zip = ZipFile.Read(localFilePath))
                    string destinationPath = @"D:\Education - FrontEnd\videos";
                    zip.ExtractAll(destinationPath, ExtractExistingFileAction.OverwriteSilently);
            // Determine the final destination path
            string finalFilePath = Path.Combine(@"D:\Education - FrontEnd\videos", fileInfo.Name);
            session.RemoveFiles(remoteFilePath);
        session.Close();
catch (Exception ex)
    // Log any errors
    System.Diagnostics.Debug.WriteLine("Error occurred: " + ex.Message);
Re: .Net Assembly SCP download to Windows always stops after476 mb
