Annoyance when copying File Names
Questioner
For some reason, filenames containing one or more spaces are wrapped with quotations. Would it be possible to wrap them all with quotations, or none at all?
Here is an example of 2 copied filenames
"this is a test directory"
this_is_a_test_directory
Re: Annoyance when copying File Names
Questioner
I can't generate a log as I'm using the local mode. Instead, I'll tell you the exact steps to reproduce it.
  1. create 2 files or folders. Name one without any spaces (this_is_a_test), and the other with spaces (this is a test).
  2. Press Ctrl+A, then Shift+Ctrl+C (or Ctrl+Alt+C).
  3. Paste the results into notepad or any other text editor.
  4. Notice how the file/folder with spaces will be wrapped in quotations ("this is a test"), while the other one won't (this_is_a_test).
