Waiting for the server to continue with the initialization
todd@onsiteitservices.net
Central Time, USA
Curious where the issue is at, if it is on the receiving SFTP server or my side running the WinSCP program. After receiving multiple
I receive a
Remote side sent disconnect message
type 11
as you can see in the log file attached to this message. Here again I am not sure if my WinSCP is considered the "remote side" or the SFTP I am trying to connect to. Please clarify and also, what I need to do to fix the connection.
Central Time, USA
RE: Remote side sent disconnect message type 11
Yes, possibly, but I am still not sure which server is the "remote side".
Is the "remote side" the server (at the remote location that I have the credentials to connect to) from my SFTP server (my side is actually a Windows 10 PC)? I assume this is correct, but not sure, just need some clarification.
What would be the definition of a GlobalSCAPE server? Is the software version, hardware, other?
What needs to be fixed on their end or mine?
Re: RE: Remote side sent disconnect message type 11
In the context of WinSCP connection, the remote is the server you are connecting to with WinSCP.
GlobalSCAPE server is SFTP server software.
I do not know what needs to be fixed. That's what I wanted to identify by doing some tests against the server.
andrew502
uk
Is anyone able to verify if removing the % from the login banner allows the login? I think WinSCP doesn't like default login banner. Any servers we removed this from seemed to work.
