Passive mode
Re: Passive mode
"Passive mode" is term from FTP protocol. It has no meaning for SFTP/SCP. But the way SFTP/SCP works resembles more passive mode of FTP then the active mode.
estrar
Okay, because I can't connect to my web host, and the support tells me that I should change to passive mode, and then it would work.
j
trying to connect using "passive mode" (or otherwise)
Are you sure that your host allows SFTP/SCP access?
I have the same problem - it's not the host that's the issue, it's the local network security. VPN intercepts all traffic on all ports except 80. Any ideas on how to work in that environment?
Re: trying to connect using "passive mode" (or otherwise)
You can setup SSH tunnel thru the port 80, if the remote server allows you to do so.
