Automated File-filtering
i thought about a Feature that automaticly skips Files by a Human-set Filter...like Date (if Host-file is older then Server-File, then send it, else skip)...or Size (if Host-file size is bigger then on the Server, then send, else skip)
And if you dont set any Checks (nothing will be filtered) the WinSCP does the same as normally..ask if existing files should be overwritten and iterate through all of the Files
Would help if you just do a Backup and the Files on the Server get updated every now and then....i guess that would reduce the Transfertime because the Programm doesnt have to send EVERYTHING....just the Files that have been Changed will get sended (sended File is bigger or got edited after the existing)
