Integration with PuTTY – new features
Good afternoon!
I have been using it for a very long time, everything is fine, but still there is a small flaw :)))
The connection to the console via PuTTY is integrated, but the password has to be entered with handles all the time during each session..
And it is not always at hand, while it is stored in the connection profile. You can develop an ADVANCED settings tab, in which there will be a checkbox or something of this type, ticked and the password is entered automatically! After all, it will be really convenient! Well, or even give an additional PuTTY profile initially combined with the connection settings, albeit on a separate tab. There are either the same details or different, but I wrote it down once and use it.
