Internal error fz#init (0200). Invalid access to memory.
filippo.dona
Hello, I have a problem with a script launched via WinSCP.com
This is mail command.cmd file
cd D:\works\script\WinSCP
WinSCP.com /script="D:\works\script\download-ordini-ftp.txt" > "lastLog.txt"
type lastLog.txt >> "D:\works\script\download-ordini.log"
The download-ordini-ftp.txt contains these FTP commands
open ftp://myusername:mypassword@myserveraddress.com
cd orders
get -delete *.txt D:\works\script\orders\
If I run the script from cmd terminal everything works fine. If I run the script through Windows Scheduled Tasks I get the following error message:
Please help us improving WinSCP by reporting the error on WinSCP support forum.
Exit code: 1
Max roundtrip: 0
I also tryed with /loglevel=2 but I can't get more informations
Re: Internal error fz#init (0200). Invalid access to memory.
Please attach a full session log file from both environments (using the latest version of WinSCP).
filippo.dona
Hi Martin,
I inform you that now everything works correctly. I don't understand why but this morning the scheduled task runs correctly. If the problem recurs, I will attach the operations log as you indicated.
Thanks for the time you gave me.
